Hi Flow Cats
Old Jan 22, 2004 | 11:10 PM
JimJr's Avatar
Hi Flow Cats
I have all stock exhaust except for an electric cut out before the muffler.....i want to put hi flow cats in there but was wondering if i will only need two instead of the four already in there. any ideas?
JR
Old Jan 22, 2004 | 11:56 PM
TrackBeast's Avatar
Cats
I am building a system with cats from Random Technology. They claim that they flow the best on the market. 582 CFM per cat.
2 is fine. The first 2 are only pre cats for warm up
TB
Old Jan 23, 2004 | 12:29 AM
JimJr's Avatar
do they just run straight pipes through the pre cats or leave them on?
Old Jan 23, 2004 | 10:11 AM
brain bypass's Avatar
how much are you paying for those random techs, which model are u using, where are you getting them from? i plan do do something similar.
Old Jan 23, 2004 | 11:54 AM
TrackBeast's Avatar
I am calling them on Monday to talk to them directly. Their cats have the best finish and flow rate which I have encountered and unlike Bassani, they meet emissions. There have been alot of issues with Magnaflow cats lately.
TB Check with me on Monday PM
Old Jan 23, 2004 | 12:05 PM
01Lightning's Avatar
JimJr,
What other mods do you have? If you are fairly stock, you are going to KILL your low end torque...
Old Jan 23, 2004 | 12:08 PM
TrackBeast's Avatar
Not if you use the proper crossover.
These guys are the best.
www.drgas.com
Old Jan 23, 2004 | 05:14 PM
JimJr's Avatar
basically stock right now.......ordering a 5lb predator and filter the first week of february so i figured i'd be ok installing these after i get all the stuff on. what do you think? will the hp gains be enough to accomadate the loss of low end torque? it should gain some top end right??
Old Jan 23, 2004 | 05:51 PM
easterisland's Avatar
Why not put cut outs on each side befoe the stock cats. That would be the best of both worlds.
Old Jan 23, 2004 | 05:56 PM
JimJr's Avatar
i have one on there right now but the retard that installed it...installed it after the cat. already ordered the cats........think i could sell them and just fix the cut outs?
Old Jan 23, 2004 | 05:58 PM
I'd say if you already have the cats do what you have planned. It would probably be cheaper. Either way it probably doesn't make a huge difference.
Old Jan 23, 2004 | 06:05 PM
JimJr's Avatar
sounds good...........just dont want to kill the low end torque like someone said i would.
Old Jan 25, 2004 | 08:04 PM
tlfwatch's Avatar
Wink LIGHTNING STOCK EXHAUST NOT BAD/
If its lightning exhaust your are talking about unless you are running over five[5] hundred horsepower then why change they are a certain amount of back pressure that should remain. like my friend said sound does not make horsepower but you sure can lose some if your not careful high flow mufflers will lose you some horsepower but if its sound you want then go for it/
