Line Lock Light
Old Jan 19, 2004 | 06:05 PM
chief40al's Avatar
Question Line Lock Light
I just got my line lock kit.
Any ideas where to mountthe red light?
Everything else looks easy.
Old Jan 19, 2004 | 07:31 PM
Casey02L's Avatar
You don't have to use it at all, but I did. I hid mine is the vent on floorboard(the top left side of the drive shaft tunnel). It's out of the way, but still visible for whatever reason.
Old Jan 19, 2004 | 07:37 PM
JeffsLightning's Avatar
How ironic because I have mine in the same exact plce. I did change the light though to a smaller more brighter one...
Old Jan 19, 2004 | 07:46 PM
todd abbott's Avatar
I like switches and the like to be hidden so for me the overhead console is a good choice, the glove box ( in a location that can be viewed from the drivers side ) , if you have a column gauge pod ( no factory material has to be drilled ) ,inside the ash tray location. I haven't seen the kits coming out of our trucks but a lit switch is an option that way only one hole for both the LED and switch but I would check with the supplier to make sure thats OK. Good luck, Todd
