Help in removing the fan....
Old Jan 19, 2004 | 02:00 AM
AZ fun's Avatar
Which way does the large nut turn coming off the water pump????
Old Jan 19, 2004 | 04:53 AM
macracer18's Avatar
are you trying to put a lower pully on or somthing cuz if so you don't need to take it off
Old Jan 19, 2004 | 05:20 AM
dirtchicken's Avatar
Stick a pry bar between the bolts on the water pump pulley and use a cresent wrench to break the fan loose. Turn it counter clockwise to break it loose. I just did it about a week ago. Let me know if you have trouble.
Old Jan 19, 2004 | 06:11 AM
Fast Gator's Avatar
Yeah, what he said, but shouldn't you be molesting your landlords daughter
Old Jan 19, 2004 | 10:21 AM
AutoPCSystems's Avatar
or are you replacing it with an electric one? if so i have a quick fix for that one...
