First Time Dyno Numbers.....Safe or ???
Old Jan 18, 2004 | 11:46 AM
Griffey's Avatar
Put the Lightning on the dyno at LaMotta's performance for the first time yesterday.Started out with 382.50 HP / 493.88 TQ.After the reburn it went to 410.95 HP / 528.55 TQ.The bottom line on the graph(in green if you can tell) was the original a/f .The red is after.Much more of a flatter a/f numbers.The a/f pretty much stays between 11.7 to 12.1 after the reburn.I haven't done a search to look at other graphs,but do most just have a sweeping kind of curve to them like that?Not real "peaky"at all lke I would have thought.I wish I had a scanner to get a better pic of the graph.This was with the stock eaton and 15lbs of boost.
So does this look relatively safe or am I going to be picking up pieces soon?
Old Jan 18, 2004 | 11:52 AM
camcojb's Avatar
Looks fine to me. Good numbers, was that on a race tune?
Jody
Old Jan 18, 2004 | 11:57 AM
Odin's Wrath's Avatar
A/F looks good. You should be fine with that tune.
Good numbers, too.
Old Jan 18, 2004 | 12:00 PM
Griffey's Avatar
No it was on just on some regular old 93 Mobil pump.Single street chip.
Old Jan 18, 2004 | 12:26 PM
Jaxtoy's Avatar
Question
What mods do you have!!
Old Jan 18, 2004 | 12:27 PM
camcojb's Avatar
Very good numbers. My race side with 14 psi of boost only made 413 rwhp and 528 rwtq.
Jody
Old Jan 18, 2004 | 01:22 PM
Griffey's Avatar
It's all stock...LOL..Aren't they all?
Other then the pulley,and a couple of other do-dads such as a t-body,long tubes/exhaust,electric fan,heat exchanger,air aid cold air, 2001 and up mass air (mines a 2000)ngk tr6's,and a converter.
The gears have also been updated to the 3.73's,and have traction bars.I also have updated the shocks to the Bilsteins.I'm not sure if the intercooler has been updated/recalled but I think it may of been.
Should be getting some track numbers soon.They will be on some good old F1's so I'm not expecting anything crazy.
