Blower belt sizing
Old Jan 17, 2004 | 07:52 AM
JeffsLightning's Avatar
Blower belt sizing
There seems to be some confusion on whats the correct size blower belt for different lower pulley sizes...Does anyone have a reference handy? Thanks
Old Jan 17, 2004 | 08:34 AM
todd abbott's Avatar
Jeff I know I was told for a 4 lb lower and a Reichard 1-2 pound upper to buy a Gatorback ---675, and I believe for just a 4 lb lower a Gatorback ---680. I hope that helps a little. Todd
Old Jan 17, 2004 | 12:18 PM
Certified Drunk's Avatar
Belt Guide
Lightning: (stock upper)
REM 2lb pulley, use Gatroback 4080675
REM 4lb pulley, use Gatorback 4080680
REM 6lb pulley, use Gatorback 4080685
REM 8lb pulley, use Gatorback 4080690
All applications are measured with OE Lightning Upper
Old Jan 17, 2004 | 12:52 PM
Originally posted by Certified Drunk
Belt Guide
Just to make sure I understand the length correctly 4080690 is a 69" belt and 4080685 is a 68.5" belt right? There is a vendor here telling me different....
Old Jan 17, 2004 | 01:13 PM
billarf's Avatar
Below is some pulley and belt info I gleened off the boards over the last few months:
Lower Pulley measurement:
Stock = 7.5"
2lb = 8.0"
4lb = 8.5"
6lb = 9.0"
8lb = 9.5" I think ...?
Goodyear Gatorback 4080660 SC Belt
1999-current Ford Lightning & 2003-current Harley-Davidson F-150
*** to be used with 2 lb. Upper & Stock Lower SC Pulleys ***
Goodyear Gatorback 4080670 SC Belt
*** to be used with 2 lb. Upper & 3 lb. Lower SC Pulleys ***
Goodyear Gatorback 4080675 SC Belt
*** to be used with 2 lb. Upper & 4lb. Lower SC Pulleys ***
Goodyear Gatorback 4080680 SC Belt
*** to be used with 2 lb. Upper & 6 lb. Lower SC Pulleys ***
Here's the GatorBack part number for the -accessory belt- on an L: # 4080990
NOTE:
You L owners, anywhere it says 2# upper this is stock upper..
Old Jan 17, 2004 | 04:30 PM
400HPHD's Avatar
Someone should have a spreadsheet on all the applications people are running and the correct beltsizes...I am running a 8# lower and a 2.70 upper with a Metco 100mm idler and I use a GB 4080680.....
Old Jan 17, 2004 | 06:11 PM
LatemodelRacer2's Avatar
I have a 4lb lower and sotck upper with a 68" Napa belt.
