High RPM sputter??
Old Jan 13, 2004 | 08:51 PM
400HPHD's Avatar
High RPM sputter??
Tonight I heard what I believe was my first detonation...I revved it aty about 35 to pass someone and as the RPM's grew high I heard a "sputter" kinda sound....Could this be detonation? I recently just installed my 2.70 upper, SBTB, JLP ram air, and other mods...I have a chip but it isnt tuned for any pulleys, was that detonation I heard???
edit: It was more in the exhaust system than in the motor....just to clear that up!
Old Jan 13, 2004 | 09:22 PM
01BlackL's Avatar
Detonation sounds like a bunch of marbles rolling around in a coffee can, that's the best way I can explain it. What RPM were you at when you heard the stutter? Is it possible you hit the rev limiter?
Old Jan 13, 2004 | 09:31 PM
400HPHD's Avatar
Didnt looka t the tach but if I had to guess it was around 4500-5000. It definatly didnt sound like marbles, more deep tone than that...
Old Jan 13, 2004 | 10:29 PM
Rob_02Lightning's Avatar
Isn't it a bitch to pick out a noise over all that.
Between the Eaton Screaming Wind, and my Accu Fab Whistle,
I can't hear a got dam thing, but when my filter clogged at the
track, and I toasted 3 plugs, it started detonating and
there was no mistaken "something was wrong" ???
Sounded more like a gang of bandito's under my truck
with sledge hammers
OR SOMETHING ???
A toasted plug will give you a spudder too,
BE CAREFUL 400HPHD, I see your from Ohio, I got to assume
your having some serious temps too. But a 2.7 pulley shouldn't
be anything to worry about, many run it with no chip.
Did you set up the TB ???
It's real simple, if you didn't when you get a chance, check it.
Here's my "HOW TO" on it
http://www.fastndelirious.com/forums...hp?threadid=88
Old Jan 13, 2004 | 11:11 PM
400HPHD's Avatar
Rob, Yes Ohio is having some real weird temp changes so far this year.....I am looking at the TB thing right now..thanks for that link!!!
Old Jan 13, 2004 | 11:25 PM
400HPHD's Avatar
Rob...do all Accufabs need to be adjusted like this?? And if so, what are the side effects of not doing it and having a bad reading....
Old Jan 14, 2004 | 06:25 AM
Yes, they all need to be adjusted, even if you buy it with a TPS
already installed. I can tell you for a fact that's the correct info
in my "How To"
What it does when not adjusted correctly I truthfully DO NOT
know ??? But mine seemed fine when I put it on, and as my
link there showed, it was waaaaaaay out of wack.
But everyone say's you got to adjust it, so I did.
Maybe someone else will pop in with a better understanding
of what it would do if incorrectly adjusted ?
