Snout question
Old Jan 10, 2004 | 05:14 PM
400HPHD's Avatar
Snout question
i just recently swapped upper pulleys and after this time upon initial start-up I can hear a faint "rattle". Now I have swapped upper pulleys countless times before and I used JLP's puller/press everytime. Did I damage something this time? Truck runs fine, and the noise is only noticable if I get real close to the blower when its running, it does not get louder when more RPM's are there....Any ideas?
Old Jan 10, 2004 | 05:18 PM
Suavy's Avatar
Sounds like you should be ok. If you did not put any inward pressure on the shaft there should be no issues.
What year is your truck? If you didn't remove the snout assy. there should be no issue with the coupler alignment ethier.
Peace, Suavy
Old Jan 10, 2004 | 05:23 PM
400HPHD's Avatar
Suavy, It's an 01....I did not remove the whole snout assembly...I didnt think it was too major but I was a little concerned...
Old Jan 10, 2004 | 05:32 PM
Suavy's Avatar
OK, good luck hope to see you at the track this year.
Suavy
