Updated General Info
Old Jan 6, 2004 | 02:32 PM
TampaBlack99's Avatar
GENERAL
Tire Size (18x9.5) = F1’s 295/45 ZR18 - BFG G-Force TA’s 295/45/18
Tire Pressure = 32 psi (Cold) / 30 psi (Hot) / 27 psi (Track)
Spark Plugs = NGK BR7EF's (2 range colder) / Beru S1K’s
Gap Good for Stock to 4lb (.036 - .038)
Lug Nuts = 100 Ft-lbs (99/00)
Stock Fuel Pressure = 36-38 psi @ Idle / 52-54 psi @ WOT
Alternator = 130 amp (Stock)
Battery = 540cca
BELTS
Stock 8 Ribbed Belts = Gates
Serpentine Belt = GatorBack 4080990
S/C Belt (stock) = GatorBack 4080665
(2 Lber) = 4080660 (66”)
(2 Lber) = 4080670 (67”)
(REM 2 Lber) (4 Lber) = 4080675 (67.5”)
(6 Lber) = 4080685 (68.5”)
FILTERS
Oil Filter = Mobil1 M1210 / Motocraft FL-820S
AMSOIL SDF-11 (6 months or 12,500 miles) 3
Fuel Filter = Motorcraft FG-986B / AMSOIL GF326
Deep Trans Filter = Motorcraft FT-114
Oil Separator = F300-02-5IY (Arrow Pneumatics)
S&M Air Filter = 9” R40-009PS (90mm MAS)
Cab Filter = AMSOIL AF1057
FLUIDS
AC = Dupont R134A
Motor Oil = AMSOIL SAE 5w30 XL-7500 (7,500 miles)
(5.5 qts) 100% Syth-Hi-Performance 5w30 (25,000 miles or 1 Year)
Intercooler Reservoir = 25/75 blend of Prestone and Distilled Water
Transmission = AMSOIL Synthetic ATF (TF128) (90,000 miles) 3
(7.5 qts) SAE Spec Motorcarft Mercon (30,000 miles)
Radiator Coolant = E2FZ-19549-AA (75% Distilled Water and 25% Coolant)
Power Steering = Royal Purple Max EZ
Mercon ATF (same as transmission)
Differential = AMSOIL Series 2000 Synthetic 75W-90 Gear Lube (3.5qts)
+ 1 Bottle Slip Lock / Mr Gasket - Form-a-Gasket
SuperCharger = 50 Weight Red Line Synthetic Oil (6oz.)
(only fill to hole) GM S/C Oil #12345982
BRAKES
Fluid = DOT 4
Stock Pads = Semi-Metallic
NAPA Ceramic Pads = CMX-7576 (Front) CMX-7584 (Rear)
MISC
Good Wax for Black = Pinnacle Souverδn / S1000 (Bikeshop)
Throttle Body Idle Screw = 650-700 RPM (TSP = .99 VDC or Lower)
General Purpose Grease = AMSOIL Series 2000 Synthetic Racing Grease
Deep Trans Pan = FORD RACING M-7195-T
PVC Valve = AMSOIL HV196 / Ford EV-98-B
Ford Interior Spray Paint = p/n M4JZ-19M547-4245-H (Medium Graphite)
p/n F6AZ-19A316-BA (Primer)
Seat Cleaner = Blue Coral
BOLT TORQ SPECS
(8) Blower Bolts = 18 Lb-In then 33 Lb-Ft
(?) Intercooler = 53 Lb-In
(6) Plenum = 89 Lb-In then 90? Turn
(8) S/C Nose Bolts = 20Lb-Ft
Idler Pulley 18-24 Lb-Ft
Auxiliary Crankshaft Pulley 74 Lb -Ft
Pulley Cage 35 Lb-Ft
REM Pulley 35 Lb-Ft
REM Hub 25 Lb-Ft
ANYONE GOT THE SPECS FOR THE MANIFOLD BOLTS?
Old Jan 6, 2004 | 03:01 PM
rkoenig's Avatar
Tampa Black,
Are you sure your stock fuel pressure at idle is 36-38? Mine is only at 30psi. My mods are: Predator with stock tune & K&N panel filter. Is there something wrong with my truck?
Old Jan 6, 2004 | 03:40 PM
I have no idea what my fuel pressure is because my gauge is still not installed fully. This is info that was collected from other post, feel free to correct if you thinks it's wrong
Old Jan 6, 2004 | 05:20 PM
rkoenig's Avatar
Well, I just installed an Auto Meter feul press. guage a few weeks ago and mine sits right at 30psi. Don't know what other stock trucks pressure is.
