Cog belts?
Old Jan 4, 2004 | 04:18 PM
400HPHD's Avatar
Cog belts?
http://rpmoutlet.com/lightcog.htm
Can anyone explain to me how this would be good or a bad idea?? Thoughts, etc.....
Old Jan 4, 2004 | 04:48 PM
BDAZSVT's Avatar
I was told to run away from MotoBlue stuff??
Old Jan 4, 2004 | 04:53 PM
grinomyte's Avatar
hmmm, if it's what i think it is, probably little benefit. Someone sells an extra idler pulley for the s/c to inscrease belt surface area, im sure thats cheaper, and just as effective.
Old Jan 4, 2004 | 06:51 PM
cpeapea's Avatar
a while back i thought it would be a good idea to machine myself some billet cog pulleys. it would sound cool i bet, plus it would eliminate belt slip
Old Jan 4, 2004 | 07:04 PM
400HPHD's Avatar
so cog belts sound different?? or did you mean "sound cool" as in a refrence term??
Old Jan 5, 2004 | 11:34 AM
400HPHD's Avatar
I take it not too many people are diggin' this idea......
Old Jan 5, 2004 | 11:50 AM
LatemodelRacer2's Avatar
I think it is a good thing if you have the money and you have belt slip issues.
Old Jan 5, 2004 | 11:52 AM
skennett's Avatar
Cog setups are for race only applications. For street applications you want to prevent as much belt slip as possible while maintaining the ability to slip if something goes wrong (ie the boost by pass fails on a high rpm deceleration). If something goes wrong and that belt cannot slip bad things will happen.
--Steele
Old Jan 5, 2004 | 12:02 PM
400HPHD's Avatar
So judging from most peoples reaction from here and other sites, this is NOT a good street idea....
OK..thanks for the answers guys!
Old Jan 5, 2004 | 01:24 PM
cpeapea's Avatar
cog belts have a different sound as they whip air around underneath the belt, i dont see this is a bad idea at all. im not too sure about what skennet posted, ive ran cog drives on street cars before and havent had a problem, but he might have a point. i'm just not sure when a belt will 'need' to slip. a boost bypass isnt always ran on blowers, i.e. 6-71s all the way up to 14-71s and sals prototype version of the whipple.
Old Jan 5, 2004 | 02:01 PM
jimkalfakis's Avatar
Hey CPEAPEA! Do those PCV filters really work? You must be buying them by the cases? Just wondering
Old Jan 5, 2004 | 02:51 PM
skennett's Avatar
...im not too sure about what skennet posted, ive ran cog drives on street cars before and havent had a problem, but he might have a point. i'm just not sure when a belt will 'need' to slip. a boost bypass isnt always ran on blowers, i.e. 6-71s all the way up to 14-71s and sals prototype version of the whipple...
Sal posted about this a while back here: https://www.f150online.com/forums/sh...ogs#post440421
Cog belts are not used on the street for a reason. You can cause severe damage with cogs. It's ok to drive a cog car once a week around town, but even then it's suseptable to damage.
When you are doing 5000rpm and you take your foot off the gas, two things happen. One, the throttle closes, and two the by pass opens. The by pass opens to relieve the pressure from a blower that's still turning high rpms. If the by pass happens to fail, you are no longer venting boost and the pressure backs up in the motor and tries to rip everything apart. I have seen cogged Vortechs get thier impeller blades ripped right off on hard decel with a failed by pass.
Street driven blower cars use serpentine drive belts because in the case of a failed by pass, the blower tries to lock up and the belt slips instead of the blower destroying itself. If you put cogs on the Lightning, and the by pass fails, there is no doubt the pressure backup would flex the rotors to where they contact each other and the case. That would not be good.
--Steele
Old Jan 5, 2004 | 03:14 PM
cpeapea's Avatar
gotcha
but has anyone had a bypass fail to open?
as for the pcv filters, they arent filters, they are badass check valves, they actually close completely and dont allow boost into they crank case. the company is called krankvents, and were originally designed for turbo cars pushing ungodly amounts of boost.
Old Feb 5, 2007 | 11:08 PM
Dbl G's Avatar
Cog's Bad
Old Feb 6, 2007 | 12:34 AM
DirtY_Dave's Avatar
Originally Posted by Dbl G
Cog's Bad
WOW. I cant bleve the pressure backup would flex the rotors to where they contact each other ! ! Just say no
