slicks or traction bars?
Old Jan 4, 2004 | 04:11 PM
quickcanuck's Avatar
What do you guys run.....slicks or traction bars..or both? Also, regarding slicks, what size tire and rim will fit the L?
Thanks,
Michael
Old Jan 4, 2004 | 04:19 PM
NTIMD8's Avatar
Do not run slicks without traction bars!!!!
If you do then you will get axle wrap and break your Drive shaft and U-joints.
It does not matter weather you go with a traction bar (Slapper type) or the rancho style traction devices. BOth will stop axle wrap.
EDIT: I am running Hoosier QTP 28x11.5 on a 16" American Racing "Baja" rim. I think most people go with the Hoosier QTP but some opt to go with a 15 " slick but if oyu do this you have to grind down the brake caliper.
Hope this helps.
,Jason
Old Jan 4, 2004 | 04:26 PM
If you do then oyu will get axle wrap and break your Drive shaft and U-joints.
when you ran the 12's,was it on both? and also, i too am going all JLP. Do you recommend John's bars over the Cal tracs?
Old Jan 4, 2004 | 04:34 PM
400HPHD's Avatar
Quick..I have a set of 16x1o American Racing Baja rims and Hoosier 28x10x16 ET Drags for sale if you are interested.....
Old Jan 4, 2004 | 04:36 PM
NTIMD8's Avatar
My track is very sticky and I run an average of 12.8 without slicks and 12.6 with the slicks. I get about 1.83 second 60 foot times with no slicks an about 1.74 seconds with slicks.
John's traction bars are the rancho style bars and work great. I have slapper bars but only because they where easier for me to get my hands on in time for when I needed them. There are a couple of minor differences in terms of how they both work. The rancho style ones have to be pre-loaded. Some say this affects ride quality other say its not noticable.
FYI my mods are....
JLP 6# Pulley
Dibalo Chip tuned by JLP
Denso IT 22 plus
Airaid intake (With custom cold air set up)
Traction bars
Slicks
Its good that you do your reaserch when modding a lightning. Many people dive right in and make many mistakes. These trucks need to be modded right in order to see gains and reduce risk of going BOOM.
I for one learnt about the traction bars the hard way A drive shaft blowing is a scary thing LOL
very interested! email me with the cost if possible m_melenchuk@hotmail.com How many passes are on them?
Old Jan 4, 2004 | 04:40 PM
[i]
[/B]
Mine went boom! Threw a rod about a month ago.
I am buying a built block from JLP as well as:
8lb pulley
Apten ported S/C
JL tuned chip
Airaid
Single throttle body
Cobra w/pump
E/fan
100 shot Nitrous Express
Old Jan 4, 2004 | 04:42 PM
400HPHD's Avatar
e-mail sent!
Old Jan 4, 2004 | 04:44 PM
NTIMD8's Avatar
8lb pulley
Apten ported S/C
JL tuned chip
Airaid
Cobra w/pump
E/fan
Yikes! Boom is not fun!! I actually remember reading about when you blew.
The new set up is going to be sweeeet!!!
Old Jan 4, 2004 | 04:48 PM
someone was telling me to at least get the cams done. Don't really know what that will give me though. Any thoughts?
Old Jan 4, 2004 | 04:50 PM
grinomyte's Avatar
yes do cams. They sound awesome and the gains are proven and very effective. Ride quality may suffer a bit however, ask your tuner. Probably be fine with a Stage II of your choice.
Old Jan 4, 2004 | 04:54 PM
NTIMD8's Avatar
I would talk to Johnny about the specifics of your set up. Cams help but can also affect driveability on a daily driver depending on how aggresive they are. Its really all depends on what you want to get out of your L. I am sure some Lightning tuners sell cams that would be good for a daily driver.
If my motor blew I think I would get the built motor + KB blower and thats about it LOL.
But like I said give JLP a call tell him what you want the end result to be and work from there given your budget.
Good luck with the new set up. It should be lots of fun!
Old Jan 4, 2004 | 07:32 PM
todd abbott's Avatar
I have JL traction bars and a set of unrun 16x10 Hoosier slicks mounted on a set of Eagle alloy convo pro style rims. The bars have been on about a year with zero problems JDM's bars are similar but I believe a bit longer. good luck, Todd
Old Jan 12, 2004 | 02:29 PM
thehammer's Avatar
8lb pulley
Apten ported S/C
JL tuned chip
Airaid
Cobra w/pump
E/fan
by the time you get the motor back into your truck
the final bill has to be close or over 10G's. you'd be nuts to be out in the street with that much hp and trq with no traction bars and proper tires.
if your lowered go with the adjustable metco bars if your not go with the rancho style bars form jdm or jlp.
and then get your self a set of ET streets.
I'm running at 500rwh and i can light my F1's at 60km no problem.
this spring its time for tires and a trip to mission.
