anyone else hate their flex a lite fan?
Old Jan 2, 2004 | 03:41 PM
ShadowBolt's Avatar
I am going to put the stock fan back on unless someone has an answer. I've melted two controllers and I still melt a wire about once a month. The guy at flex-a-lite told me it was from the connectors being loose. I crimped them so hard that I can barely get them on the controller but it still get way to hot. I think maybe the fan I got just pulls to many amps. Looking to an answer this side of going back to the stock fan.
Jerry
Old Jan 2, 2004 | 03:48 PM
desertL2001's Avatar
Jerry,
That stinks. I like the design of the fans themselves, but your experience sounds too familiar. How about keeping the fans but switching over to a regular relay-based switching system. Maybe something like this would do the trick.
http://www.derale.com/electricfanaccess.shtml
Randy
Old Jan 2, 2004 | 04:18 PM
easterisland's Avatar
My truck worked fine all last year. I pulled it out of the garage a couple of weeks ago to let it run awhile. It is a good thing I was kinda watching it. Steam started coming out from under the hood. The controller for the flexilite fan gave up again.
Old Jan 2, 2004 | 04:33 PM
wydopnthrtl's Avatar
I've heard about this problem but have had nothing but perfect function out of mine for 13k miles / 1 year. And that included one 4 hour cruise at woodward with it (AC) cranking the whole time.
Rich
Old Jan 2, 2004 | 04:57 PM
Autoscene's Avatar
i melted my controller last night.
we need a tuner to come up with a way to run the fans with the ecu and a relay.
Old Jan 2, 2004 | 05:54 PM
Jkstang78's Avatar
I think there is nothing better then a factory electric fan. I know to many people who have the flex-a-lite fans, and have them break with in a few months. If you can find a stock electric fan that will fit the lightning then go with it. I think the SN95 fan will work on those trucks. I have one on my 87 mustang now. From the looks of it, It looks like it will fit just fine. My 2 cents
Old Jan 2, 2004 | 06:07 PM
quiksilver's Avatar
Try pretinning the wire with solder before crimping on the connector, then soldering again. That will keep the resistance as low as possible, keep it from melting.
Old Jan 2, 2004 | 06:11 PM
tlfwatch's Avatar
Talking I HAVE STILL HAVE FACTORY STOCK FAN
Why because i can't take a chance i can't believe that i am losing that much horsepower with stocker untill they come up with a better system i will keep stock fan to many lightnings have bit the dust because electric fan didn;t kick on. It doesn't take much of high temp. just a minute of high tempature and she is gonejust my .02 worth
Old Jan 2, 2004 | 06:23 PM
tlfwatch,
No.... you got that wrong bud. (I was the W/P engineer for all the mod motors)
The only reason we even speced mech fans was because of towing capacities. Otherwise they would have all been e fans.
Rich
Old Jan 2, 2004 | 06:30 PM
Sharpshooter's Avatar
Rich
wydopnthrtl,
I have a Flex a lite; Will that effect my towing? I didn't put the fan until late september, so I haven't ran it during the hotter months yet. Does the mechanical fan cool the "tranny cooler" also?
Mike
Old Jan 2, 2004 | 06:45 PM
ChiDiver's Avatar
I have the Troyer e-fans and have not had any problems with them other than their desire to blow fuses the first couple of days of driving with them. Probably the bearings were a little tight. After that no problems.
What I did and think it is a good idea is to spend $2.25 at Radio Shack and buy some LED's. Tie them into the fans so you know when the fans come on. They fit quite nicely on Autometer pillars.
They come in red green and amber, so I put a green one on the low speed fan and a red on the high speed fan to let me know when they come on. I've got a pic floating around somewhere that I'll try to dig up.
The guys with FAL fans may be able to do likewise.
Kind of a lousy pic as my camera does not care for the Cyberdyne gauge.
https://www.f150online.com/galleries...4745-80793.jpg
Old Jan 2, 2004 | 06:48 PM
hslightnin's Avatar
ive been through both power wires and the fuse block but the releay is still truckin
Old Jan 2, 2004 | 06:52 PM
Tim Cowley's Avatar
I had one burn this summer. I called Flex0 Lite and thay sent me a new controller. Thay update them very often. I called the tuner I bought the fan fron and got the phone number. Good Luck.
Old Jan 2, 2004 | 09:04 PM
Hilander's Avatar
I have the JDM fan kit, been on for 2 years, works like it was built that way.
Just a suggestion, Maybe buy the JDM wiring kit?
