SHOULD OLD GASKET BE USed YES OR NO
Old Jan 2, 2004 | 10:53 AM
tlfwatch's Avatar
Exclamation SHOULD OLD GASKET BE USed YES OR NO
Doing a factory tech valve body change although ford says that old gasket is reuseable new gasket cost over $30.00 i have second thoughts about useing old gasket.also installing new 4x4 pan many mechanics say old gasket is reuseable only have 2500 miles on lightning who has done this FTVB and did you use old gasket thanks
Old Jan 2, 2004 | 11:05 AM
wydopnthrtl's Avatar
YES you can reuse the old gaskets.
No worries mate, Rich
Old Jan 2, 2004 | 11:16 AM
SVT_KY's Avatar
Let's see, $33,000 truck v.s. $30.00 gasket ... I know
which one I would use but that's just me.
If you can't justify spending $30, maybe you belong in a
less maintenence hungry vehicle. <grin>
Old Jan 2, 2004 | 11:22 AM
Fordsrus's Avatar
I reused the old gasket with no problems with the Morroso trans pan.
Old Jan 2, 2004 | 11:28 AM
denny0328's Avatar
i re-used the old gasket aslo with the moroso and had no leaks at all!
Old Jan 2, 2004 | 11:36 AM
Silver_2000's Avatar
isnt it printed on the pan that the gasket is designed to be reused ?
badasstruck1's Avatar
I have had my pan off my L 5 times and reused the gasket every time with no leaks as of yet nock on wood!
Old Jan 2, 2004 | 11:40 AM
DL's Avatar
DL
If you like throwing money away, get a new gasket. If not reuse your gasket, that's what I did. Local Fords techs don't use new ones, unless they look real bad.
Old Jan 2, 2004 | 12:26 PM
PoorSvtMan's Avatar
Just did my FTVB yesterday and reused the gasket.
Old Jan 2, 2004 | 12:33 PM
MaxTorque02's Avatar
The gasket is intended to be reused. Why throw $30.00 away if you don't need to.
Old Jan 2, 2004 | 12:39 PM
tlfwatch's Avatar
THANKS YOU ARE RIGHT FORD SAYS IT IS WASTE OF MONEY
Thanks guys you are right ford tech told me if i had money to burn ok. But that gasket will last from now on why waste money on something you don't need.
Old Jan 2, 2004 | 12:41 PM
l-menace's Avatar
yeah you can use that $30.00 to ALMOST fill up your gas tank
Old Jan 2, 2004 | 03:27 PM
svt00L's Avatar
Me too...and I reused it!
Old Jan 2, 2004 | 04:35 PM
tlfwatch's Avatar
Wink WHAT AN AWESOME MOD NOTHING LIKE IT/
Why didn't i do this FTVB mod before now WOW is all i can say will save my transmission also thanks fellows for your input and encouragement/ TOM
Old Jan 2, 2004 | 08:48 PM
billarf's Avatar
Re: SHOULD OLD GASKET BE USed YES OR NO
It is a reusable gasket so YES, reuse it! Most everybody reuses it!
