# pulley a BITCH
Old Jan 1, 2004 | 03:01 AM
secstang03's Avatar
4# pulley a BITCH
Happy New Year everyone. It took me 5 1/2 hours and I just got the 6 front plugs done. What a BITCH!!! #3 on the drivers side is a *BITCH*. I have a guy that will change the back 2 ( Back 1 on each side) for $40. You bet your *** Im taking him up on it. Its the same guy that did my heads when I spit a plug. He should know what he is doing.
So we have the 6 front plugs gapped @ .038 (amazingly enough all plugs have been gapped at .038 from NGK( Tr6's)
ROB- where u at. All the write ups I have seen say CLOCKWISE
except yours. ( a little to much to the point) That makes me wonder if I am turning this ****ING bolt the right way. It has to be. Everyone says that except you (I know that funky **** makes you forget :o))I had the torgue (sp.) convertor locked down and everything removed except the lower pulley. The tool that RPM supplies me with is a piece. That thing is at its end. You would think that it would be forged steel or something. That is the weakest piece of **** I have ever seen in my whole life. I have made 3 trips to HiLo, 2 trips to Sears Hardware & 1 trip to Autozone ( and I almost forgot 1 trip to Walmart) and I am still lacking 2 back plugs.(But, Im done with that!! I give up!! $40 is worth it to me for the last 2)( I shoule have taken Steve (HALO?) up on his offer) Yes I am kicking myself in the ***!! LaPorte or not I should have done it!!!!!)
:d
I am ****ed up and Rambling on New Years Eve!!!!
Anyways I need help guys. The Hex (?) it looks like on the lower pulley of a '99. What in the hell do you guys take it off with. I know it can't be what I have. I cant get a 1/2" drive socket in it. A 3/8" is to small. I have tried the biggest Toque (sp.) I can find along with the biggest Allen I can find. It is something right on. Maybe Metric??? Either way I have tried everything I can thing of - up to the point of breaking the piece of ****** tool off in my pulley. 100+ lb. fts. ( thats what the "how to'so" sayand that BITCH still wont break lose.
WHAT THE HELL?!?!?!?!!!?
P.S. Am I the only guy up at this hour wondering whats going on with his trcuk??? Probably so!!!
Old Jan 1, 2004 | 03:41 AM
LatemodelRacer2's Avatar
you lost me man. Maybee the bolts are metric i know the three that hold the cage on are.
Old Jan 1, 2004 | 03:47 AM
andrewjhaley's Avatar
What bolt? Cause everything I have read to take off the lower pulley is COUNTER CLOCKWISE.
Old Jan 1, 2004 | 07:49 AM
evo's Avatar
evo
My Metco directions for the lower cage pulley removal is to turn the bolt clockwise(loosen). But that is for my 03'L.
Old Jan 1, 2004 | 08:15 AM
superfords's Avatar
well, I don't know if you were drunk or high when you typed that, but it was new years eve so I suppose it's ok.
in any event, if you are trying to take the the center of the lower pulley loose then you need a 14mm hex bit and a 1/2" breaker bar.
turn it CLOCKWISE to loosen.
good luck.
later,
chris
Old Jan 1, 2004 | 10:07 AM
Patrick_PDX's Avatar
5 1/2 hours for 6 plugs ?
What are you using for tools ? A butterknife and a monkeywrench ?
Old Jan 1, 2004 | 11:38 AM
camcojb's Avatar
That is very funny!!!!!!!!!! My guess is that he doesn't have the correct tools though. I took an hour and 45 minutes the first time I did the plugs on mine, and did them in under an hour the second time.
Jody
Old Jan 1, 2004 | 12:47 PM
madferraristi's Avatar
The OE pulley to harmonic damper thread is left hand. Facing the engine, turn that sucker clockwise, if you can.
Man I'm glad I slathered mine up with Neverseez when I built my engine. Came right off when needed.
Old Jan 1, 2004 | 09:44 PM
gp's Avatar
gp
a lift and a good,long and strong piece of pipe is a must.sounds like a shot gun when it breaks loose.
Old Jan 1, 2004 | 10:02 PM
Robert Francis's Avatar
When I took mine off a couple of years ago(2001 model), for a while ,I didn't think I'd ever break that 14mm bolt loose. Hard to get much leverage laying underneath raised om jackstands. I put the longest piece of pipe I could fit underneath there - about 2 foot on my breaker bar - and it finally broke loose. The job is easy on a lift.
Old Jan 1, 2004 | 11:02 PM
SVT_KY's Avatar
The stock pulley is a left handed thread ... The tool is
first rate if it's the same as the PSP kit ... I have used mine on
6 different occasions and always got it off eventually.
Persevere my friend ...
