remove mods for service?
Old Dec 29, 2003 | 03:56 PM
brain bypass's Avatar
i am going in for my 12k service, should i take the mods off, or just take it in as is. i really don't want to remove my pulley, that would be a pain.
Old Dec 29, 2003 | 08:47 PM
tlfwatch's Avatar
Question KNOW YOUR DEALER
My dealer is mod friendly what kind of service are you having done and it depends on how well you know your dealer. my dealer is going to install my Factory tech valve body friday.
Old Dec 29, 2003 | 08:59 PM
ShaneMcKenna203's Avatar
For a 12k service I'd think you may be able to keep them on. Vs going in there for a broken rod, or a launched plug...
But like tlfwatch said, it all depends on the dealer and your mods. Most of the time it just depends on your dealer. Some dealerships see a single mod, and can void the warranty after that. I was very lucky to have my transmission covered after I had a chip, pulley and the Factory Tech Valve Body. Hope I was able to help some, but like I said it's up to the dealership if they are mod friendly or not.
good luck, Shane
Old Dec 29, 2003 | 10:19 PM
Mastertvtech's Avatar
What does 12K service include?
Lew
Old Dec 30, 2003 | 12:14 AM
captainoblivious's Avatar
What are your mods? And is your dealer mod friendly?
Old Dec 31, 2003 | 08:02 AM
don't know about the dealer, but i don't think it should be a problem. i know the general manager of the dealership. i wouldn't do it, but i want to get my brakes checked out. i have to bring them oil to put in it, because they don't carry mobil 1
12k service includes:
Change Oil & Filter, Lube (up to 5 quarts) 5W-20 Synthetic Blend
Balance & Rotate Tires (including brake inspection) and a Multi-point Inspection:
Check Air Filter
Check Front & Rear Brakes
Check Belts
Check Lights
Check Hoses
Check Tire Wear
Check Steering System
Check & Adjust Tire Pressure
Check Suspension
Check Wiper operation & blades
Check Exhaust
Check Battery Terminals
Old Dec 31, 2003 | 10:07 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
ummmmmm
save some change, do it yourself, save the receipt for the oil, enjoy a festive beverage.
Old Dec 31, 2003 | 10:09 AM
halflife's Avatar
Don't chance it and just do it yourself.
