My dream driveway
Some more nice driveway shots...
Looks good LitnFast. Some more nice driveways pics...
My dads fastback, my truck and my old bike, and a member with an 03 Cobra and an L.
Those are some damn fine driveways. Especially the ones with the M3 and 03 Cobra. Soon I'll getchas some picks of my driveway with an 03 Lightning, an 01 Lightning and a 1990 Mustang GT. Great pics guys!
How bout this driveway?
The Cobra isn't mine but I wish.... That's my Dads car, he got it a couple weeks ago, I had the pleasure of waxing it for him, and so I snapped a couple shots while I was at it
: D The 76 T/A is mine though
This post makes me sad. Here is or should I say "was" my driveway this spring. I sold the Camaro. The mods where are listed below.. Looking at the pics makes me very sad
396 CID LT1 Stroker/Super Charged
Eibach lowering Springs
Polyurethane motor mounts
4340 Forged Pro Series Crankshaft 3.875 inch Stroke
Lunati Forged 4340 Billet Connecting Rods 6.0 inch
Lunati Custom Forged Pistons
Childs and Albert Ring Set Plasma Moly Ring Set
Clevite 77 H Series Racing Bearing
Melling HV Oil Pump
ARP Main Studs
ARP Head Bolts
Billet 4 Bolt Mains
Rotating Assembly Fully Balanced and Engine Blueprinted
Custom Hydraulic Roller Camshaft
GM HP Timing Chain
ARE Fully Ported Intake Manifold (58mm Throttle Body Ready)
Twin 58mm BBK Throttle Body
ARE LT1 Stage 3 Cylinder Head
CNC Type Porting on Entry and Bowls
Fully Hand Ported Race Prepped Cylinder Heads
Competition 3 Angle Valve Job
Stainless Steel Manley Race Flo Valve 2.10 Intake / 1.60 Exhaust
Resurface Heads to Desired Compression Ratio
Chrome Moly Lightweight Retainers / 10 Degree Racing Locks
Competition Cams Hi Performance Valve Springs
Comp Cams 7/16" Screw-in Rocker Arm Studs / Comp Cams 5/16" Guide Plates
Viton Valve Seals
CC Combustion Chambers
Set all Valve Spring Pressures and Heights
Comp Cams Moly Pushrods
Crane Gold 1.6 Roller Rockers
"O" ringed block
Motor was bult with a 9.5:1 compression ratio
ATI Supercharger kit with 2 core intercooler (running only 7psi of boost) Car was built to handle over 15psi.
50lbs/hr injectors
NOS (Holley) 12-920 Inline Fuel Pump
Accel Ignition and coil
MAC Headers and y-pipe
MAC 3" cat back system with stock muffler
Flow TEch cut out with QTP Electronic cut out
OBX Racing custom touring seats
RCI 4 point belts
Hurst Comp Pro shifter
MBA engraved "Z28" 8 Ball shift ****
Custom made full A-pillar gauge pod
SLP Ultra-Z hood
WW mid wing
Custom Pearl in black with transparent Neon Blue paint
After Market sound system including 2 10" Clarion Subs, sony speakers mids and tweets, In dash CD/Tape player etc..
Melling HV Oil Pump
ARP Main Studs
ARP Head Bolts
Billet 4 Bolt Mains
GM HP Timing Chain
Viton Valve Seals
"O" ringed block
50lbs/hr injectors
RCI 4 point belts
SLP Ultra-Z hood
WW mid wing
Not my dream Driveway, but it's the best picture I could get.
BTW: the SS is not mine, I sold my last chevy car(a 88 Monte Carlo SS) to that same guy so he could use it as a daily driver. Now all I have is an Toyota SUV for the wife
Ooohhhhhhh.....
I want to play!
Remember...this is a "dream" driveway. In this dream, all the vehicles are problem free and never require service, and if you go by the dealer's service department, it's only because they love seeing you and treat you like royalty when you visit, not to mention they detail the vehicle for free.
I want to play!
