Convertor Lockup
Old Dec 25, 2003 | 11:00 PM
Calightnin's Avatar
Convertor Lockup
If your 1-2 upshift is 43 mph ...... when do you lock up your torque convertor .... and why?
Old Dec 25, 2003 | 11:56 PM
Spanky99L's Avatar
are you running a 112 or 140? how much boost?
thanks
Old Dec 26, 2003 | 12:57 AM
Calightnin's Avatar
I have a 140, and boost depends on the day.
Im just curious what opinions there are about convertor lockup for racing only. Seems most lockup down low (30 mph or so), but I also read on other forums (using other vehicles) that people command lockup in third gear. Looking for an education on this topic.
Old Dec 26, 2003 | 01:53 AM
skennett's Avatar
My PI converter locks up in 2nd gear at WOT... If that helps...
--Steele
Old Dec 26, 2003 | 06:58 AM
cpeapea's Avatar
mine locks up around 50 or so if im not still accelerating, i think most of that can be changed with a chip i think
Old Dec 26, 2003 | 10:22 AM
owheelies's Avatar
I don't know the MPH points but I believe at WOT it is just after the 1-2 shift. If you wach (and listen) to the clip of Bill (HDmllnium) running the 10.?? you can destinctly here his lock up shortly after the 1-2 shift.
Eric
Ps. His must be set pretty well as he can run 10's in the heat all day!
