Which Autolite Plug is Best?
Old Dec 23, 2003 | 09:36 AM
TampaBlack99's Avatar
I plan on switching out my plugs when I change my manifold to a 01. For a truck with 4lbs of extra boost which plug should I be using, the AR93's or AR103's.
What's the difference in both, how much colder are they than the stock plugs?
Anyone know the torq specs for the manifold bolts?
Thanks and Merry Christmas!
Old Dec 23, 2003 | 10:28 AM
Blwnsvt01's Avatar
Spark plugs????
I changed plugs after i installed my JLP 4lb lower pully and went with DENSO IT22 and could not be more satisified the idle is smooth and everything in between to WOT. just my opinon- I have a spare set if u are looking to buy some Denso.
Old Dec 23, 2003 | 10:43 AM
Thanks, but I think I want to go with the Autolite's.
Old Dec 23, 2003 | 11:14 AM
yysenhimer's Avatar
I've had nothing but problems with Autolite plugs every time I have used them on performance cars.
I have never used them on the Lightning.
Old Dec 23, 2003 | 12:35 PM
Flintstone's Avatar
check with sal
been a while he did test autolite{search maybe)
Old Dec 23, 2003 | 04:58 PM
fast1's Avatar
I don't know anybody that uses Autolites in a Lightning.
Old Dec 23, 2003 | 05:25 PM
skennett's Avatar
I believe the 103's are what you are looking for.
FYI - Others have reported rough idle, slugishness, and no increase in performance from these plugs.
--Steele
Old Dec 23, 2003 | 05:48 PM
Bad as L's Avatar
skennett is right, the plugs will run fine but will feel "flat" for lack of a better term.
Wich is strange cause when I had a turbo buick the Autolites had the exact opposite effect, it was the only plug to run for a long time. Dale
Old Dec 23, 2003 | 06:58 PM
LightningToGo's Avatar
Yo Steve, I use Autolite AR93 and just love them. I got them from REM.
Old Dec 23, 2003 | 08:17 PM
Autoscene's Avatar
is ar93 colder or hotter compared to tr6?
Old Dec 23, 2003 | 08:34 PM
LTNBOLT's Avatar
Colder.
The AR103 is the same heat range as the TR6 according to the cross reference charts and NAPA.
I tried to get some AR103's today with no luck. Carquest use to have them but show them discontined from stock. No luck at NAPA either.
The regular 103's are the plugs with the flat throttle response. I know because I tried them a couple of years ago. They have the wide and long ground electrode that shrouds the center electrode. I believe this is why the throttle response is so bad on the regular 103.
AR93's are the only ones I could find. I'm afraid they will be too cold and miss at low RPM like BR7's.
Old Dec 24, 2003 | 12:12 AM
LTNBOLT's Avatar
George,
Do your AR93's miss or sputter at low RPM?
Old Dec 24, 2003 | 07:56 PM
Originally posted by LTNBOLT
George,
Very very little while at idel. Low rpm to WOT is great!
Old Dec 24, 2003 | 08:50 PM
captainoblivious's Avatar
I say don't bother with the autolites either, at least on any performance vehicle. Go with either the Denso's or NGK's.
I'm running autolites on my GTI (15psi from the turbo) and lately I've been getting rough idle, and a slight degrade in response which I suspect to be the plugs. So I'm going to be changing out the autolites and see if that solves my problems.
But the NGK's in my truck, no problems at all with them.
Old Dec 25, 2003 | 12:04 AM
LTNBOLT's Avatar
The idle thing is normal for any copper plug.
Capt.,
Are you running the AR's or the regular plugs in the GTI?
