Removing Lower Left Dash
Old Dec 18, 2003 | 09:42 PM
tlfwatch's Avatar
Exclamation Removing Lower Left Dash
Removing lower left bottom part of dash is that much of a problem trying to get to head light switch to hook up phamton gauges want to connect wire that when headlights come on gauge lights will be on also thanks
Old Dec 18, 2003 | 10:48 PM
Don's Bolt's Avatar
The headlight switch comes right out.
There are some clips that hold it in, very carefully stick a little jewlers screw driver in the little slots and it will slide right out.
Old Dec 19, 2003 | 11:00 AM
Konig's Avatar
Its a little bit of a biznitch to get out the first time... just be careful and dont scratch up your dash doing it... I used two jewler screw drivers at the same time to make it easier...
Old Dec 19, 2003 | 11:09 AM
00redLrod's Avatar
Registered User
also if you have a cup holder light you can use that as a power source, not sure if the 03's have that light or not though
