Belt size for a 3.25 upper and 8" lower????
Old Dec 18, 2003 | 09:41 PM
Kart90's Avatar
Im putting on my KB so....... Can someone tell me what size belt to run on a 9" lower and a 3.25 upper? Im in need of a part# to. Gates would be great.
2001White lightning
Old Dec 18, 2003 | 10:08 PM
ken800's Avatar
with my kenne bell... on an 8lb lower and a 3" upper, I have an 080680 and it is a pretty snug fit. If have snapped your tab stop off, it will be ok I think. If not, you probably need to go to a 685.
Old Dec 18, 2003 | 10:11 PM
VINNIE's Avatar
Same here 8# lower 3 inch upper 080680 and ZERO belt slippage.
Old Dec 18, 2003 | 11:11 PM
1 SILVER BULLET's Avatar
Same here 8# lower 3 inch upper 080680 and mucho belt slippage
Old Dec 19, 2003 | 12:20 AM
Kart90's Avatar
Im running that (85 belt)now with a 9" lower and a 2.81 upper . U think it will still work?
So you guys are running 8# lower which is 9.XX inches correct?
BTW what tab are you talking about?
Old Dec 19, 2003 | 04:53 PM
HIHOAG's Avatar
Yeah,
What size in inches are you running on the lowers.
Stock = 7.5"
2lb = 8.0"
4lb = 8.5"
6lb = 9.0"
8lb = 9.5"??
I have an 8.5" with a 3.25" upper and run 16lbs boost.
Mark
Old Dec 19, 2003 | 08:17 PM
Kart90's Avatar
6lb. lower and a 3.25" upper. So a 080685 will work?
