XE270AH comp cams?
This probably isn't going to help much but I had Comp custom grind a set of cams based on the 274 lobe. So my cams are 274/274 on a 113 L/C. I am running these cams with a solid lifter lashed at .003 intake and .004 exhaust so the actual duration is less.
Problem is I just got the motor in the truck and haven't got it running yet, other wise I could offer some input. Soon.....very soon
Dale
. Dale
I have the XE279AH in my truck and love them......I will have some audio clips in the next few weeks. Also have a truck that will have the cams you are refering to completed shortly. Hold tight for another week and I will have more info.
Tom 's Truck sounds rowdy, I heard it in person and I want the same cams he has.
tommylightning
tommylightning
Originally posted by madferraristi
tommylightning,
What vacuum do you have at idle in gear? What is your idle rpm?
tommylightning,
