LFP headers?
LFP headers?
I was looking at getting a set of LFP longtubes. Is it possible just to install headers to the stock cat pipes? i know the pipes will have to get cut back some, but you dont have to change them do you?
Re: LFP headers?
01svtL I've got a few pics of LFP's headers if you wanna take a look at em'. I talked with Mark about them a few times. I guess his are Tri-Y collector (3 to 1) vs 4 to 1. He said his headers and cat combo would help out a lot. More info on Tri-Y collector High Flow cats are only like $250, personally if I did long tubes, it would be to get the high flow cats too.
Shane
on the subject, has anyone just got high flow cats with there cat back set up, but stock manifold? if I did get long tubes, I'd get high flow cats too, im just asking can you put high flow cats onto the stock mid pipes?
thanks, Shane
thanks, Shane
Bassani sells high flow cats and mid pipes the work with the stock manifolds and cat-back. Not worth the money. Spend a little more and get the L/T's and high flows. I think the Bassani high flows are $500-$600 range.
thanks, Shane
thanks, Shane
You'll have to rip out the old cats, get a mandrel 90 degree (or 45 degree) bend, and have them custom welded in place.
