JL Drive Shaft Loop?
Old Dec 5, 2003 | 05:42 PM
LightningToGo's Avatar
Does anyone have instructions for JL DS loop. It arrived today with no instruction.
Thanks!
Old Dec 5, 2003 | 05:48 PM
fractaldragon's Avatar
I have the instructions but didn't need them. There are already holes in the frame rails to mount it to and just bolt it on. Took me longer to put the truck on jackstands than it did to install the loop! Need a 3/4" deep socket and 3/4" wrench.
Old Dec 5, 2003 | 06:09 PM
ShaneMcKenna203's Avatar
Yeah I don't remember even looking at the instructions. All you have to do is line it up to the wholes in the frame, and bolt it up...
I used two 3/4ths sockets and I did it while the truck was on the ground, no jack, or anything. Good luck, Shane
Old Dec 5, 2003 | 07:48 PM
Rob_02Lightning's Avatar
If it's a two piece design like Sals
Here's a few crappy pic's
Old Dec 5, 2003 | 08:30 PM
tommylightning's Avatar
Just installed one today! Just jack up the truck and put a jack stand under. Then look at the frame, at the part before it goes up you will see a hole on either side. You will mount the long bar using these holes. Make sure the 4 holes drilled in the long bar align up under the driveshaft. Now put the U shaped bracket over the driveshaft. Tighten the nuts and bolts up and you are done.
