Auto meter Fuel sender location
Dose every one just put the sender on top of the fuel rail or do you mount it on the fire-wall and run a Stain steel hose to the fuel rail? Just wondering. Waiting on the UPS Man.
If it is a AutoMeter(electric only) gauge they sell an adapter that goes right on the Schrader valve on the rail I think it is part #3280 if not Scummit knows the number. It is the easiest way to install the guage but you will loose the schrader valve so if you motor vac or 3m clean your injectors you will have to dissassemble. I was thinking of changing my set up and adding a tee fitting and keep the Schrader it is only 1/8"NPT thread I am preety sure.They make pleanty of High PSI stainless steel/brass fittings to do this
C-ya
Slick
C-ya
Slick
