Dumb Q - How to install tailights
Old Dec 1, 2003 | 10:42 AM
scott015's Avatar
have a 2000 L, so tailights are red... just tracked my clear ones and they come in tomorrow.... so I know this is probably a stupid question, but how do I install them?
Old Dec 1, 2003 | 10:43 AM
99svtlightning's Avatar
Just open the tailgate and the screws are next to the lights on the inside. If you are using the factory scews, you need to cut about a 1/4" off or they will go through the inside of the taillight and ruin them.
Old Dec 1, 2003 | 11:12 AM
engelmb's Avatar
Pretty straight forward...two bolts on each side. Easy mod!!! Just did mine a couple of weeks ago. Just make sure, as mentioned above, you cut the bolts or you will put a hole into the new lights. I was lucky enough to get a hold of the bolts from 01+ L to solve this problem. Did you get the clear headlights, too?
Old Dec 1, 2003 | 11:24 AM
scott015's Avatar
ok, guess i didnt see the bolts in the rear because my truck has a bed liner.... i guess i will have to remove that...
anyway, truck already has the stock clear headlights, but aftermarket clear side pieces.... i am doing the 01+ projector lights and sides next....
Old Dec 1, 2003 | 11:33 AM
engelmb's Avatar
Scott,
The screws are not located in the back, they are on the side. You will see them when you open the tailgate. Also, the 01+ headlight look different. They are a lot cleaner looking than the 99-00. I just upgraded mine and it makes a huge appearance difference. At least in my mind it did. Good luck.
