clunk still here with washers
Old Nov 29, 2003 | 12:11 AM
hslightnin's Avatar
i got the washers from jdm and the clunk is still chillin
what else could it be?
Old Nov 29, 2003 | 12:30 AM
MaxTorque02's Avatar
Re: clunk still here with washers
When exactly does the clunk occur? What's the tread wear like on the inside of your front tires? If it happens when you make a slow sharp turn it could be that one or both of your tires are worn on the inside. You probably need an alignment, but that shouldn't effect the clunk. It will just help your tires wear more even.
Old Nov 29, 2003 | 01:02 AM
hslightnin's Avatar
Re: Re: clunk still here with washers
i installed the roush kit about 3 months ago and had it aligned then, thats when it started clunkin bad in sharp turn like pullin into a P spot
Old Nov 29, 2003 | 01:14 AM
007IGHTNING's Avatar
Smear a small amout of grease on the wheel bump stops.
When you make a hard turn and the wheel turns to its maxium turning point, your getting metal to metal contact which makes that annoying sound. I have the washers, and had that sound too. I was informed by another member to do what i just explaind to you, and problem solved
John
Old Nov 29, 2003 | 01:21 AM
hslightnin's Avatar
what would somthin like that look like?
Old Nov 29, 2003 | 03:21 AM
thepawn's Avatar
I get the noise all the time, and just havn't gotten around to puttin grease on the stop yet...
It looks like a little cylinder sticking out of the side of the arm, you'll see a corresponding "shiney" spot on the wheel hub where the two parts meet.
Old Nov 29, 2003 | 03:32 AM
grinomyte's Avatar
hey pawn can we get that pic just a little bigger?
