Vacuum / Boost?
Old Nov 28, 2003 | 08:46 PM
Suavy's Avatar
Vacuum / Boost?
Vacuum / Boost?
I just finished my rebuilt motor again the last time I noticed 10 psig. of vacuum on my Auto meter Boost / vacuum gauge. This time setting at idle it reads 21 psig of vacuum. During normal driving it maintains 10 psig. of vacuum.
Is that normal?
Reason for rebuild was 3 blown piston rings 3-bad pistons, 3 bad valves and guides. We also repaired the passenger side head which had 3 lobes where the spark plugs come through that were melted about 20% .
Suavy
Old Nov 28, 2003 | 08:50 PM
400HPHD's Avatar
Thats exactly what I see.....well ...almost exactly.
Old Nov 28, 2003 | 08:57 PM
Suavy's Avatar
Do you have a built motor also?
I have port and polished heads & intake and 1MM over sized valves.
Thanks for the info
Suavy
Old Nov 28, 2003 | 09:02 PM
400HPHD's Avatar
Nope sorry.....stock block with the esxception of Manley rods....not that, that would effect anything. I see around 10 at cruising and about 21-23 at idle.
Old Nov 28, 2003 | 11:07 PM
Suavy's Avatar
Thanks for the info.
Suavy
Old Nov 29, 2003 | 12:09 AM
Spanky99L's Avatar
that about what i see on my built motor.
I see anywhere from 19-21 idle and about 10 going down the highway.
Old Nov 29, 2003 | 11:20 AM
bluballz's Avatar
I see about the same also.But just for g.p. the boost gauge reads boost in psig it reads vac. in in.hg which is inches of mercury.Now what its equivilent to as far as psig im not really sure i havent had the chance to check that out yet.But yeah,i see about 10inhg at cruise then when i let off i see about 21-20 inhg.
mike
02 true blue
jdm enhanced
6#,chip,filter,full length exhaust,
throttle body,heat x-changer,&
traction devices
11.98@112(so far)
Old Nov 29, 2003 | 02:55 PM
easterisland's Avatar
That is pretty close to what I see and I have the above. Except the intake and heads aren't polished.
Old Dec 1, 2003 | 10:34 PM
Suavy's Avatar
Thanks for the info. It's cool to have my truck runing again! I'm driving it like a frigging grand ma right now! I haven't even broke the tires loose yet!
Old Dec 1, 2003 | 11:19 PM
l-menace's Avatar
I'm sure you thought of this, but if you put it on a mustang dyno they can similate a 1/4 mile run, shiftng through the gears and sucha and monitor the engine at specific speeds and RPM's.
Food for thought.
Old Dec 1, 2003 | 11:42 PM
l-menace's Avatar
BTW:
park that thing, there is salt on the roads!
