Upper pulley install
Old Nov 28, 2003 | 08:07 PM
tlfwatch's Avatar
Red face Upper pulley install
Need a little help with this one i just now installed different upper pulley went from 2.85 to 2.80 the blower shaft likes about 1/8 of"inch to being to end of pulley is this normal with different pulleys i can't seem to tighten it any more but i am not stongest person in the world either any thoughts or suggestions on this one belt seems to run straight??????? thanks for your help
Old Nov 28, 2003 | 08:25 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Head to AutoZone and 'rent' a power steering puller/installer.
It has an install tool that will press the pulley on the rest of the way.
NOTE: Make sure your truck is cold when you press it on the rest of the way.
Bada BING!, or something.
Bob
Old Nov 28, 2003 | 08:50 PM
tlfwatch's Avatar
Wink ???already have proper puller
Already have proper puller made for the lightning s.c i have pressed it on as i stated it acts like it don;t want to go any futher thats why i ask if anyone has any ideals i know how to remove and install was asking is this normal on some pulleys likes just a hair coming to end of pulley
Old Nov 28, 2003 | 09:49 PM
dirtchicken's Avatar
When I did my upper pulley it came with two different length screws. I used the longer one to start, once I couldn't get the pulley all the way on I used the shorter one to get it on the rest of the way.
Old Nov 28, 2003 | 09:52 PM
400HPHD's Avatar
Holy triple post Batman....You must be using the JLP puller, its the same one I used numerous times....Every single time except 1 time the pulley sat flush ewith the snout. The 1 time is was only off by a mm and I just left it that way...5000 miles and problem free.
Old Nov 28, 2003 | 09:55 PM
understood Chief.
However, 1/8" isn't aligned properly IMHO.
I struggled a bit with JL's pulley installer (his removal tool ROCKS BTW) then went the AutoZone route for the press. much easier and doesn't cost a penny.
Bob
Old Nov 28, 2003 | 10:02 PM
Rob_02Lightning's Avatar
Same thing happen to me too, I even broke the bolt trying to force it on the rest of the way. The next day I switched to a smaller screw like Dirt said, I also removed the washer I was going through before threading it in the S/C snout.
THAT SEEMED TO DO IT, it then went right on like it should have
in the 1st place
GOOD LUCK
