Lowered- alighnment no`s?
Old Nov 26, 2003 | 12:12 PM
Dean Phillips's Avatar
2" drop and getting cam bolt kit on an `03. Does any one have all the no`s for the caster, camber and toe. The alighnment shops in the UK won`t have this info unless I get it. Will the set up no`s be different from standard because it`s lowered?
Thanks.
Old Nov 26, 2003 | 12:19 PM
Justin@JDM's Avatar
Banned
Use these specs for best drivability...
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Old Nov 26, 2003 | 01:15 PM
grinomyte's Avatar
is there another type of alignment you would recommend? Saying drivibility seems to imply that you would recommend different settings for different things. . . . just curious.
