Need your advice
Old Nov 25, 2003 | 05:42 AM
outnumbered's Avatar
Need your advice
What is the best fuel system set-up? I currently have overkill in my opinion. I have a Weldon pump that I want to take out and replace with the normal 255 pumps (2). My question is, I also have 1/2 rails with 50lb injectors, -8 supply line and -6 return. Should I keep all this, or should I simply put the stock rails and lines back on? I already know that I will be replacing the 50# injectors with 55's, but I'm not sure about the other plumbing. The truck stumbles a bit off the line, and shuts off after the truck has been driven a while. I think these quirks are all a result of my fuel system, hence me wanting to change to what everyone else is doing.
Old Nov 25, 2003 | 08:32 AM
Dan_03Lightning's Avatar
Can't help you with the best fuel deliver system, but if you end up moving to the 55's, for the right price I might be interested in the 50's if you want to sell? What is the brand of injectors you currently have?
I hope someone with know how gives you an answer. I know for myself I have the cobra 255 pumps and I have max'd the stock injectors. My tuner told me all I need are the 50's or 55 injectors and I will be all set. There hasen't been any talk of changing lines or rails. I am pushing 496/562 currently, but with 16lbs out of my KB the 42's just can't keep up.
Let me know, dpearson@fortmyer.gannett.com
Good Luck!
D-Day
Old Nov 30, 2003 | 10:41 AM
Dan, I already sold the 50's, but thanks anyway.
Old Nov 30, 2003 | 11:12 AM
MISTERgadget's Avatar
you'll be better off in the long run keeping the "overkill" fuel system, than switching back and realizing it's inadequate eventually.
