Guys with built shortblocks....
Old Nov 24, 2003 | 06:59 PM
WaveBlaster785's Avatar
What kind of pulley/pulley combinations are you running, and what kind of times are you getting out of them. Also what kind of HP/TQ??
I'm having a block built and would like to see what everyone is running and how they like it. I have the basic bolt ons, FTVB, 2-way chip, 4lber, headers, hi flows, bassani, cai....
My goal is low 12's, maybe even 11's.
Thanks in advance,
Ed
Old Nov 24, 2003 | 08:15 PM
Spanky99L's Avatar
8lb lower 1lb upper stock eaton
i see 15-16lbs on my autometer depending on the weather. i have ported and polished heads with 1mm oversized valves, longtubes high flows etc
Will
Old Nov 25, 2003 | 12:33 AM
I know more than one person on here has a built shortblock....
Thanks Will.
Old Nov 25, 2003 | 07:44 AM
tommylightning's Avatar
I have a "built" motor running an 8# lower and a 2.75 upper seeing about 16# of boost. The heads have 1mm larger valves and port work. CompCams stage III cams and springs.
I have also sprayed it with a 150 shot!!! Still needs some tuning but is running great......Oh did I mention it is a daily driver
Times are in my sig!!!!
