Stock Factory Speakers
i created a post about a week ago asking what size the speakers are and everyone said 6x8 in both the front AND the rear...
I am planning on getting a MTX Thunderform that holds 2 10"s... but would like to upgrade the regular speakers first.... so I have a few questions
1. can I get something better than 6x8 for the front? if so, will i have to do some customizing or not? what is best for front?
2. with subs in rear, should i even change the rear factory speakers at all?
3. what is a really good speaker? i was thinking MB Quart
Re: Stock Factory Speakers
If you have a budget in mind and tell me what kind of music you listen to, I can recommend a pretty good system for you.
i listen to mainly alternative music... 3doors down, staind, pearl jam, etc... but ocasionally i like to listen to a little rap like eminem...
i dont really want alot of bass, i would rather it sound clear and good with some bass than so much bass it distourts the music...
so what size component? 5 or 6" and what exactly do i do with the 1" tweeter that is comes with??
also, the mtx thunderform says 500watts rms... does that mean 500w each or 250w each??
any suggestions on a good amp for the subs and for the components
I fit 6.5 inch components in my old L. You just have to make an adapter plate out of some 1/4 inch MDF. Use a good hole saw for the tweeters and you're done. Just make sure you go with a seperate amp for the components.
I have the subs in the back, and you can see the tweeters in the door. And the amp for the components is under the passenger seat.
