Anyone else get 10.5 lbs of boost stock?
Tim, Im not doubting you got more boost with a new filter, I saw a extra 2lbs with mine. I had a electronic Boost Guage several years ago and it wasnt accurate at all. It was often off by as much as 3lbs when I was running a total of 12lbs. I also noticed the same problem with the electronic Fuel pressure gauge. Its been about 4 yrs and maybe they have improved in time.
Originally posted by AmoJohnny
im completely BONE STOCK...and i hit 10+ psi on my 03, everytime...but the temps have to be under 60. I then disconnected my boost bypass, and now it gets pegged at like 11 or 10.5 and is stuck there through every gear...Its badass dude...cant wait to get the k&n on there...how long do ya people normally go on stock air filters?
Originally posted by BigFan
Tim, Im not doubting you got more boost with a new filter, I saw a extra 2lbs with mine. . . .
I can't see any way that the butt dyno would miss an extra 2.5 lbs of boost, which would neccessarily translate into double-digit HP numbers.
BTW, my electronic boost gauge is a new model which has only been out a year or so. At $190 MSRP, it had better be pretty damn close to perfect!
I saw a guy dyno his stock L last week. Three pulls with the stock air box(NO filter) got a best of 363RWHP.
Put the K&N panel back in for the fourth pull and got 371RWHP!!! I don't know what happened, but I saw it. I heard some talk about "smoothing the airflow".
Jstas Dyno Run
Go Figure
Fred.
Jstas Dyno Run
Go Figure
Fred.
