*LIGHTNING*/HD Predator Released!
Old Nov 20, 2003 | 09:27 PM
JohnnyLightning's Avatar
LIGHTNING/HD Predator released!
We @ JLP will also be marketing the predator.. We will not sell this unit under the pretense that this unit will *NOT* Void your Warranty..remember*any* modification you do to your vehicle could possibly void your warranty..We @ JLP will offer our years of Knowledge and *Tuning* abilities of the Lightning/HD trucks.. This is a *new* unit and we @ JLP have had a hand in working with the *tunes* in the unit. however there will be changes needed to be made with each vehicle. NO 2 vehicles are the same.. there are *thousands*of different modifications and combinations on *Thousands* of lightnings/HD. which will need some kind of change to get the most out of there mods. Thats where we @ JLP can help you get your *Specific* Combo Dialed in.. We have been *modifying* the Predator for the 03 cobras with Great Success. We have an in house Dyno Jet to check and re-check ALL parameters to get as close to perfect as we can. We have the software in house to write our own *JLP* Files and will upload them to your Predator. We are very confident you as our Customer we be very pleased with the end result.. The *set* price is $419.00 and we also will be offering *FREE* Next Day Shipping. And will be offering Our JLP *Custom* Tune Along with our years of experience.if interested give us a call 717 786 4670...or order from our website. Thank you......JL
Old Nov 20, 2003 | 10:17 PM
blown318's Avatar
Re: *LIGHTNING*/HD Predator Released!
I see you finally got the dyno up and working!!!!!
Old Nov 20, 2003 | 10:41 PM
I Dyno'd sues HD @ 17# of boost, pump gas, Stock cats and stock manifolds it made 530rwhp,630 trq. i'll be putting in some 116 octane and 23# of boost next week to see what we can do..... JL
Old Nov 20, 2003 | 10:42 PM
l-menace's Avatar
so HONESTLY how does thing thing work.
I know it reflashes the stock computer
and it has a bunch of gizzmos and do-hickies....
so if I get one PRE-Programmed, and I get bored can I start screwing with the settings? That would only lead to an explosion or something.....
No but seriously. I've read all about it's features, but what value is this to a normal (moderately modded) lightning owner.
I'm not flaming, I need more info on what and how it does what it does and what i can screw up with it
Old Nov 20, 2003 | 10:46 PM
Rob_02Lightning's Avatar
I already have a couple of Diablo Chips now,
(The one I use is JLP tuned of course)
but I can still see me getting a predator in time.
I'm told I can plug it in, make a pass, and get TRUE
A/F and timing #'s. Then "if need be", "I" can tweak it a tiny bit (in only 2 minutes) and dial it right in.
And I believe I can also take that info, email it to the tuner, and have a TRUE CUSTOM PROGRAM made FOR ME and send back to me via the net
SMOOOOOOOOOOOOOOKING
Old Nov 20, 2003 | 10:50 PM
Grey03's Avatar
Hope this helps;
DiabloSport Predator Part # U7158
Applications:
- U7158 - 1999-2004 5.4L Supercharged Lightnings & 2002-2003 Factory Supercharged Harleys
Features
Dyno Tested Performance Tunes:
- Diablosport has generated dyno tested tunes for factory Supercharged Lightnings/Harleys.
- 3 Tunes will be offered standard*:
Tune 1 - For Factory Boost Level (8#'s).
Tune 2 - For up to 12-14#'s of boost total (+4 to +6 over factory)
Tune 3 - Factory HP Tune (Stock Tune): Factory calibration tune only (allows use of below end-user options with factory tune).
- Average power gains are in 20-30 HP in the Supercharged SVT vehicles.
*Note: 1999-2000 Lightnings will have 5 tunes standard:
Tune 1 - For Factory Boost Level (8#'s) for factory 80mm MAF
Tune 2 - For up to 12-14#'s of boost total (+4 to +6 over factory) for factory 80mm MAF
Tune 3 - For Factory Boost Level (8#'s) for Ford 90mm MAF
Tune 4 - For up to 12-14#'s of boost total (+4 to +6 over factory) for Ford 90mm MAF
Tune 5 - Factory HP Tune (Stock Tune): Factory calibration tune only (allows use of below end-user options with factory tune).
Diablosport Predator Performance Tunes Re-Map:
- Fuel Curves (at all rpms and throttle positions)
- Timing Curves (at all rpms and throttle positions)
- Extend Speed Limiters
- Extend Rev Limiters
- Part and Full Throttle Shift Points
- Shift Timing
- Shift Pressure
Diablosport Predator allows the end-user to make the following fine tuning adjustments:
- Idle: Will adjust for both Drive and Neutral
- Axle Ratio: Can adjust from a 2.xx up to a 5.xx in .10 increments
- Fuel Base: Will adjust from -15% to +15% for PE mode
- Spark Advance (Timing): Will adjust from from -10% to +10% for PE mode
- Rev Limit: Will adjust for both Rev Limit drive and Rev Limit neutral. Allows user to adjust ON/OFF rev limits, for each individual gear, in 10 rpm increments. Allows up to 6000 rpms on Lightnings/Harleys.
- Shift Points: Will adjust in 50 rpm increments for each gear.
- Shift Firmness: Will adjust for each gear.
- OBDII: Allows turning of Bank 1 and 2 Rear Oxygen Sensor ON/OFF, or ALL O2's ON/OFF, AND EGR system.
- Wheel/Tire Sizing: Allows adjustment and correction of speedometer for larger/smaller tires.
DiabloSport Performance tunes require the use of Super Unleaded/ Premium grade fuel only, Amoco, Sunoco, or Mobil, if possible.
Diagnostic Capabilities:
- Predator can read and erase fault codes, and contains all the Ford specific P codes.
- Predator diagnostics will work on all 96-04 OBD-II Ford Mustangs or F-Series Gas vehicles.
Live Data Logging and Monitoring Capabilities:
- Predator can monitor over 400 tuning parameters. - Predator can log tune data, at 90 samples per second, for at least a 30-minute period, to be viewed on the Predator screen or be exported to a PC, either live or logged, using FREE software supplied by DiabloSport.
Predator Feature Selling Points / Ford Lightning/Harley
- The only flash tuner on the market that allows for end user adjustability to the performance tune, enough adjustment to allow for pulley changes in factory-supercharged engine applications.
- The only flash tuner on the market to accept custom DiabloSport programs, and can be done via using email/internet through your dealer.
- The only flash tuner on the market with advanced diagnostic capability.
- The only flash tuner on the market with data logging and monitoring capability.
- The only flash tuner on the market with a backlit screen, that’s also 300% larger then the competition’s screen.
Van Halen
Old Nov 20, 2003 | 10:53 PM
RhinoSlug's Avatar
Wow. Thats pretty intense. I havent really done any reading on it but what is the learning curve on using this chip. Can someone read the manual and all of a sudden start screwing with their air fuel ratios? Is this chip going to lead to whole bunch of shadetree mechanics blowing their motors? Just a thought.
Old Nov 20, 2003 | 11:00 PM
rhino: the predator comes with a step by step manual. before you start *modifying* the tunes that are already on the predator i would make sure you discuss this with an experienced tuner. We @ JLP will help you make the right choices to help you achieve your goals *safely*...JL
Old Nov 20, 2003 | 11:05 PM
RhinoSlug's Avatar
Sound advice. Thanks for the reply, JL!
Old Nov 20, 2003 | 11:09 PM
blown318's Avatar
Old Nov 21, 2003 | 07:00 AM
Lightningquick's Avatar
I could be wrong here but i would think that JL already done the research and found the best tunes for said application.basically i feel that if there was a "better" tune combination JL would have found it by now.Basically this tuner is gonna make alot of people "think" they are a tuner now and blow some trucks up
Im sure it will be fun tp play with but i see more bad then good for the general public.I do agree that if the time is taken with a certain truck ,one could possibly get the "right" tune for "them" but they should be VERY careful doing it.
I hope this doent sound too negative cause i think i would like to have one but just think there is alot of room for destruction with all of us power greedy owners
.02
Old Nov 21, 2003 | 08:23 AM
ken800's Avatar
I'm going to grab one... I'm interested in the ability to tune shift points, tire sizes, shift duration, etc. I'm also interested in the datalogging portion as well.
Think about it... You have a flip with a couple of different programs. With this you can tweak it for the street/track without having to have several programs.
If you need a tune for the a/f, timing, etc., yes, I would rely on your tuner to make those changes, but for the other stuff, it's nice to be able to change on the fly... If you do need to be richened, leaned, timed up/down, etc., you get an EMAIL file and reflash your predator, then reflash your truck... If your truck is "out there" like mine, a stock program isn't going to work in any way. I'd be down having to ship back and forth.
An autotap (in my opinion the best low dollar datalogger and scan tool) is about 350 bucks. Everyone should have one... For another $69 you can have a datalogger that sounds to be pretty good (the 90 samples thing is really interesting to me) and you tune all sorts of stuff with the same device. It's a killer deal if you ask me...
One of the retailers carrying this product is here in texas. I won't mention their name but I drive by them everyday at high RPMs. They've cooked enough motors that I know of that I wouldn't go near them with a 10' pole... Make that 100'...
Old Nov 21, 2003 | 08:44 AM
loosebolt's Avatar
I've heard that if you have a base program and want to make adjustments yourself, you can only go like 5% each way. So, if my timing is set at 15 degrees, the most I can advance it would be 15.75 degrees. Is this correct?
Also, I thought it only held 1 program in memory, so you can't be at the track and switch between 2 or 3 programs, unless you have a laptop with you that is holding all your programs. Is this correct?
Old Nov 21, 2003 | 08:56 AM
halflife's Avatar
SOLD!!!
Johnny coming to your shop Tuesday for a Dyno tune. Time to dump the diablo chip and get the predator.
See you then.
Old Nov 21, 2003 | 10:15 AM
ken800's Avatar
do you have a notebook computer? If you do, you could have as many of your programs as you want stored right there...
