Code “P0213” Cold Start Injector 1
Old Nov 20, 2003 | 02:46 PM
oldfrmtrk's Avatar
I added the Krank Vent TM Kits, it ran fine, and the engine seemed to run smoother, silkier, That’s when I decided to go for it floored it the boost went up to 10.5 unusually I only get 9 very seldom 10. Took it down to 65, it was great. Upon seeing another opening in the rush hour traffic I WOT one more time, when I got down to snail speed service engine light came on. Got home and took the Passenger Vent off then I reset the light and checked the code “P0213” Cold Start Injector 1 Malfunction, I know that “P” is Power train The “O” is SEA, and the “2” is Fuel and Air Metering (injector Circuit) but I have no cle what is the 1 and 3!! Can any body shed any light to this??? The code did not come back this morning…
Old Nov 20, 2003 | 03:53 PM
oldfrmtrk's Avatar
Wow, nobody has a clue??? Maybe somebody can recommend a site where an Lightning owner can find some assistance!!
Old Nov 20, 2003 | 04:26 PM
Edward's Avatar
It's only been an hour since your initial post. Why not try waiting?
Old Nov 20, 2003 | 04:56 PM
Silver_2000's Avatar
if you had googled for ford odb ii codes you would have found this
http://www.svtlightnings.com/scantoo...tc%20codes.htm
I guy I know hosts that site - it just lists the same "cold start injector malfunction"
You could try a ford service DVD to see if it has trouble shooting steps for that code
Doug
Old Nov 20, 2003 | 05:38 PM
oldfrmtrk's Avatar
Excuse me! I was trying to motivate a small spark of emotion! It worked.
What in heavens name is “Cold Start Injector #1 Malfunction”
In another site, they said it was a vacuum leak. I have installed the Krank Vent TM Kits, it ran fine, until the second WOT run the code appeared.
I read it, cleared it, and removed the Krank vent on the drivers side. Today the code has not reaped.
Ok I deserved to get flamed!!! I donned my fire suit. Thanks….
Old Nov 20, 2003 | 06:20 PM
It was sarcasm - The site listed is my site and unfortunatly the code list has no more info
I bought a ford service DV off ebay for $40 - its at home - it might have trouble shooting steps for that code
Doug
