calling DJY1
Old Nov 17, 2003 | 06:51 PM
01FordLightning's Avatar
calling DJY1
i want to get the drop you have but i called bell tech and they told me if i put the 3" coils on then i couldent get an alighnment so when you put on the Western Chassis 2 inch A-arms did that make it where it could be alighghned?also any pics of the suspension?
thanks,
Justin
Old Nov 17, 2003 | 07:28 PM
dirtchicken's Avatar
Belltech 3" coils are 2" on a Lightning.
Old Nov 17, 2003 | 09:26 PM
DJY1's Avatar
01FordLightning,
With just the Bell Tech 3 inch coils you are only getting a 2 inch drop. I have the Bell Tech 3/4 kit with Western Chassis 2 inch Lower A-arms "yes" you can get a Alignment you just have to buy the Camber Kit for Alignment which most Alignment Shops do have on stock for Ford trucks. With just the Bell Tech 3/4 kit your rear is going to be lower than the front making your Lightning look like you are carrying a load. I would install a C-section kit because your rear end will bottom out over bumps in the road and speed bumps! If I have time this weekend I will take some pictures of my Suspension.
djy
2 inch Lower A-arms and C-section kit from Sport Truck Direct
Old Nov 17, 2003 | 09:30 PM
thanks DJY1
