taking off the lower pulley and cage
Old Nov 15, 2003 | 01:42 PM
01FordLightning's Avatar
i am trying to change my stock belt and cant get the original lower pully cage and pulley plese help i unscrewed the three bolts on the cage and it dosent come off.
Thanks,
Justin
Old Nov 15, 2003 | 01:46 PM
HIHOAG's Avatar
left hand thread on the pulley center bolt
Old Nov 15, 2003 | 01:49 PM
SLVRLTNG's Avatar
you need to loosen the middle allen bolt. It is a left handed thread.
turn it clockwise to loosen.
here are some instructions from JDM's website:
http://www.teamjdm.com/id257.htm
Old Nov 15, 2003 | 01:51 PM
easterisland's Avatar
You are going to have to make something or use a tool to stop the crank from rotating. Ford has a tool which does this. You have to remove the starter to use their tool. Most tuners have a strap which is attached to the transmission case and the fly wheel. Sometimes it can be difficult to remove the stock lower pulley. I would suggest getting a cageless 2 lb lower or something to stick on there once you get that caged pulley removed. You could probably find one on ebay or in the classifieds for $50-$100. It may even come with a pulley removal tool.
Does your belt need to be replaced because it broke?
Old Nov 15, 2003 | 02:12 PM
no i just wonted to change it to a gator back belt because the factory one slips on shifts already changed the supercharger belt and dident stop the slipping
