3M Fuel Injection Cleaning!
I just want to let you guys know about this stuff, if you don`t already.
I just performed the the fuel injector cleaning with the 3M cleaning kit on my 2000 Lighting. My truck only has around 24,000 mile on it and it made a huge difference. My truck accelerates more smoother and more rapid through the whole RPM range. You guys gotta try this stuff. I`m not talking about a "mechanic in a can" fuel tank additive. This type of service gets injected right into the fuel rail with a special hose. Sort of like recharging your A/C with the old R-12 cans. Look at the power I`m making in my sig. I`m going to the DYNO tommorow so I will get the after results and post them.
My kit looks different, of course I bought it a few years back when I had my own repair shop. The kit cost me $100 and the pressurized can (chemical) cost about $15. I used to charge $55.00 for the service, and people used to praise how their car was running like new after. The motor should run on the chemical for about 15 minutes.
http://products3.3m.com/catalog/us/e...er/output_html
Yea, that's the kit I found at 3M a few weeks ago. Now, tell me where to buy it......... I emailed 3M about it and never heard back from them on a distributor, etc. I'm sure 3M only wholesales their products.
No, my Snap-on guy doesn't sell then. Snap-on has their own system which is for shop use, not consumer use.
I would love to buy it cause it(the theory) does work! You shut off the fuel pump and the engine runs on only the cleaner for a few minutes. The only better(IMHO) cleaning method is to pull the injectors and send them off to a shop.
Dan
Dan
Hey LIGHTNINGROD, They sell the kit in auto parts stores.
All you need is the special hose that has an on/off valve and the the two fittings, one for the fuel rail, and the other for the chemical can.
