First attempt at plug change...
Well I switched out my stock plugs with TR6's last night as my 4# pulley is being installed as we speak. Just 1,800 miles on the stock plugs so I'll keep them. My friend works at the dealer and borrow the mechanic's "secret" tools
Took a little over 2.5 hours
All in all it went well for my (our) first attempt. I did 6 myself including the 2 "bears" in the rear. The rear driver's side is a PITA!
So will I finally see a 12 this weekend? Time in my sig is with chip only and in 45-50 degree air. Supposed to be around 50 this weekend
Took a little over 2.5 hoursAll in all it went well for my (our) first attempt. I did 6 myself including the 2 "bears" in the rear. The rear driver's side is a PITA!
Originally posted by ShaneMcKenna203
2.5 hours isnt bad for first time. Joe helped me do mine the first time. I bet if I tried them now on my own it'd still take me about 2 hours or so. Good luck this weekend, Shane
The biggest problem I encountered that hindered me from getting into the 12's was traction. I know I would have been in the mid twelves, with similar mods, if I had slicks but had to settle for a 13 flat. Let me know how you do.
Re: First attempt at plug change...
Did you find any that were loose?
Re: Re: First attempt at plug change...
Originally posted by Va 01 Lightning
fractaldragon,
fractaldragon,
