Help me spend $1.000.00!
Old Nov 11, 2003 | 06:38 PM
FRANKS RED 03's Avatar
between incometaxes and work bonusus i will have a little over a grand to waste at my fingertips.I would like to know what i could do *** far as performance to my 03, I drive 40-50 miles every day so whatever i get will have to be safe and warrenty freindly,Any suggessions would be greatly apprietiated,THANKS!
Old Nov 11, 2003 | 06:40 PM
LightningCT's Avatar
warranty friendly.....you're kidding, right.....
Old Nov 11, 2003 | 06:45 PM
Rob_02Lightning's Avatar
Re: Help me spend $1.000.00!
Rob Caruso
1313 Mocking Bird Lane
Long Island, NY, 11487
Old Nov 11, 2003 | 06:46 PM
l-menace's Avatar
warranty friendly,
Factory Tech Valve body (very very very hard to tell it is aftermarket)
Air intake system (easily removed)
Cat back (won't effect warranty)
Traction bars (won't effect warranty)
Getting a chip will void warranty, wait for diablo predator! (2 more weeks)
I'd say lower pulley, but you need a chip and dyno tune and that could eat all of $1000.
Kinda hard to change when going in for warranty work
Old Nov 11, 2003 | 06:52 PM
Odin's Wrath's Avatar
Re: Re: Help me spend $1.000.00!
Originally posted by Rob_02Lightning
Robinson Crusoe
2961 Friday Crt.
Seldom NY, OU812
I don't think you'll see a $1000.00 cashiers check anytime soon. I do wince to think of the things you will be receiving in the mail though.
Old Nov 11, 2003 | 06:55 PM
Yeah hopfully thats not youre reall adress!
Old Nov 11, 2003 | 06:57 PM
I was hoping to here something like a chip and predetor for about 600,Is that reallistic or am I way off?
Old Nov 11, 2003 | 07:00 PM
Oh you want idea's
OK
Diablo Predator $419.00
usahooters@fastndelirious.com
JLP Forced Air Induction $285.00 http://www.johnnylightningperf.com/n...sp?intProdID=2
JLP Upper Pulley Kit $165.00
http://www.johnnylightningperf.com/n...p?intProdID=62
All of the above can be taken off and put back to stock
in no time at all. Ford Will never know it was touched.
And you will still have a wrrnty.
On a cool day with slicks, you'll kiss 12's
Personally I'd go for a 4lb-6lb lower, but Ford would know
you messed with that if you ever had to put it back to stock
Old Nov 11, 2003 | 07:03 PM
Dont do the track deal, But would like some more horsepower at normal ""city"" driving. With the preditor theres no need for a chip?
Old Nov 11, 2003 | 07:05 PM
Re: Re: Re: Help me spend $1.000.00!
The women can send me their Thongs
but please no under garmets from any males
Old Nov 11, 2003 | 07:09 PM
Predator Details
The DiabloSport Predator programmer provides high performance flash tuning and OBD-II diagnostics capabilities in one module. Designed for the 99 to current Ford & GM vehicles (Application List). The Diablo Predator is a tunable performance module, which utilizes flash technology to reprogram the original ECU chip for optimum performance and derivability. The Diablo Predator gives the user ability to adjust selected parameters to suit their own applications and needs. The Predator will also include diagnostic features, such as the ability to read fault codes and erase them, as well as live data from your vehicle's sensors; this technology was also borrowed from our OBD-II tool, the Hellion.
_______________________________________
Diablo Predator Features (most Gas vehicle specs listed below. Please see Diesel section and Ford Gas section for information on those specific units):
- 30-Day Satisfaction Guarantee!*
- Lifetime Warranty!
- Screen Size is 300% larger than the competition
- Ability to have customized programming which can be done via email/internet (see below**) (handheld competition does not offer)
- Quicker programming than the competition (takes approx. 2 min.)
- OBD-II diagnostic software (includes live data monitoring of MPH, RPM, IAT, ECT, LTFT, STFT, O2 Voltage, Timing, KR detection, as well as many other sensors (competition does not offer)
- Revised Torque Management Settings for optimum performance
- Eliminates CAGS (Skip Shifting) on the 6-speed manual transmissions (GM)
- User adjustability. the user can set their own parameters. Choose from DiabloSport's performance program, have a custom performance program made for you by Runnin' With The Devil** (optional feature, please inquire), or modify the performance program your own:
Axle Ratio: Can adjust from a 2.xx up to a 6.xx in .01 increments.
Cooling Fans: Will adjust both ON and OFF in 1 degree increments up/down.
Power Enrichment (Fuel): Will adjust from -5% to +5% at WOT
Spark (Timing): Will adjust from from -10% to +10% at WOT
Shift Adaption (duration): Allows user to adjust the time delay during the gear change, i.e. quickness of the shift, from -25% up to +25%
Shift Points (MPH): Allows user to adjust at what MPH the shift should take place, for each individual gear, in 1 mph increments.
Shift Points (RPM): Allows user to adjust at what RPM the shift should take place, for each individual gear, in 10 rpm increments.
Shift Pressure: Allows user to adjust the firmness of the shift action, for each individual gear, from -25% up to +25%
Rev Limit: Allows user to adjust ON/OFF rev limits, for each individual gear, in 10 rpm increments.
Wheel Sizing:
Factory Wheel Size: Enter the factory tire size in XXX/XX-XX format, i.e. 275/40-17
Actual Wheel Size: Enter the actual tire size in XXX/XX-XX format, i.e. 305/35-18
The Predator then calculates the difference in overall height for proper speedo calibration.
** For the ability to have custom programmed e-mail/internet downloadable tunes made for different performance part combinations (i.e. full exhaust, heads/cam, supercharger, turbocharger, NOS, etc.), please contact sales@runninwiththedevil.com
* By purchasing a Predator you are agreeing to the terms of the "Return Policy" listed directly below (this is also listed within the manual):
Predator Satisfaction Guarantee / Return Policy:
All DiabloSport products have a guarantee of satisfaction. If in the first 30 days from date of purchase, you are not satisfied with the results the Predator programmer generates in your vehicle, simply restore the factory tune to your vehicle and return the Predator to the selling dealer, and pending examination of the tool by DiabloSport, you will receive a refund from your selling dealer. Under no circumstances will DiabloSport accept the return of a Predator unit that has a factory tune remaining in it.
Old Nov 11, 2003 | 07:16 PM
Re: Re: Re: Re: Help me spend $1.000.00!
Old Nov 11, 2003 | 07:19 PM
Ok Odin, maybe you better edit my address
Old Nov 11, 2003 | 07:21 PM
I guess what im really getting at is the preditor alon going to make my truck faster and or save me gas,i wouldnt mind having ''longer'' gears due to my everyday highway driving.
Old Nov 11, 2003 | 07:22 PM
To go with that Predator.....
160* thermostat
Volant C/A intake kit
Factory Tech valve body
