HELP PLEASE! Can someone post a pic of a stock L ECM??
Long story short - I really need some quick help!!
I need a picture of a stock Lightning or Harley ECM w/ the port still showing the conformal coating.
If anyone has one lying around - (any tuners???) - Could you PLEASE post a pic or email me one (through the forum).
Thanks in advance. If things 'work out' I'll explain in a couple days...
I'll be forever in your debt!!!!!!! (If it works out, I'll even send you a case of
You can try here but you can't see it that well...
PCM Pictures
Trying to get a little warranty work done???
PCM Pictures
PCM Pictures
PCM Pictures
Looked at those pics... Trying to see what color the contacts look like prior to sanding them down, and how much/where the conformal coating is...
Thanks, BTW, Struck in AZ... Anyone else?? It would seriously be a life saver...
The contacts are a dull silver...almost metallic gray prior to cleaning them. A chip will rub through the top coat and make a copper-ish color. The conformal coating probably varies from truck to truck but it completely covers the contacts on both sides. I think if you're able to get a similar material and not put it on two thick Ford might have a hard time proving that it wasn't their original crap.
You might want to search on 'conformal' as I think someone may have posted what they did to return their PCM to a stock look.
Sweet... I will pick up some Testors paint, and a fine paint brush.
I was thinking of trying some hot glue on both sides - it has the same feel as that conformal coating as well
Does the coating only go over the contacts, maybe a bit past them on the circuit board? I forget if it goes over the edge as well, creating like a glob at the end or not....
Originally posted by LightningCT
hhmmmm....sounds like some one is obviously having some warranty work done.....LMAO
Let's just say that it's BS that a known issue with the 5.4 engines has to be scrutinized...
conformal coating
i think the coating you are trying to find is humiseal 1673 ap.this is used on elec.coating it has a property you will need as i do believe it fluoress in black light. that is to prevent tampering with the contacts.you should check the ecu to see if this not true.
Yea, been calling around locally for something similar.. Nobody seems to carry it.
I was thinking over heating hot glue and applying. Should appear just as the conformal does in normal light
Re: HELP PLEASE! Can someone post a pic of a stock L ECM??
but is in focus and a close up
