Gauge readings?
Old Nov 9, 2003 | 10:49 PM
svtguy2002's Avatar
Gauge readings?
What should I expect for each gauge?
1) Fuel Pressure
2) Oil Pressure
3) Water temp
4) Trans temp
I need expected readings at idle/cruising and WOT. Thanks!
Old Nov 10, 2003 | 12:27 PM
svtguy2002's Avatar
I know the Oil pressure should be 75 and the fuel pressure should be 30 around idle/cruising.
What about Fuel pressure at WOT? Oil pressure at WOT? And, for those with larger (FRPP, B&M, MAC) trans pans, what should I expect for trans temp?
Old Nov 10, 2003 | 04:09 PM
Coldie's Avatar
HHmm...
My standard readings:
Fuel pressure: 36-38 at idle, 54 at WOT
Oil Pressure: 50-75 at startup (cold) 30 at idle (hot) 50-75 WOT (hot)
Trans temp: very dependant on outside temp, 120 now, up to 140 in the summer.
Coldie
