CHIP location ????
Old Nov 9, 2003 | 05:09 PM
EastcoastEnt's Avatar
CHIP location ????
Could someone tell me where the chip is located on a 2002 L
i'm trying to find out if the owner before me changed the chip
thankyou
Old Nov 9, 2003 | 05:12 PM
Suavy's Avatar
Not sure about the 2002's but my 2000 has the computer on the passanger side just above the kick panel.
Suavy
Old Nov 9, 2003 | 05:13 PM
fractaldragon's Avatar
Underneath the dash on passenger's side. All Gen II's are there.
Old Nov 9, 2003 | 05:18 PM
goatheady's Avatar
Passenger side kick panel. You'll probably have to pull the computer to check
it. Just make sure you disconnect the battery first. Look at the end of it, if
the coating has been removed, there was a chip on it. Hope this helps.
The Ghead
Old Nov 9, 2003 | 05:24 PM
Thanks ..
ill check now
Old Nov 9, 2003 | 08:05 PM
HEVYRESQ's Avatar
What ever you do....say it with me..."DONT DISCONNECT THE BATTERY WITH THE KEY IN THE IGNITION!~!!!"
It will erase your PATS memory and your key will not work-you'll have to have it towed to fix
Old Nov 9, 2003 | 08:38 PM
E3LilE8Harv29's Avatar
Passenger side kick panel under the dash!
Old Nov 9, 2003 | 08:54 PM
LatemodelRacer2's Avatar
Its where everyone else said but it will be way up in there on the firewall against the side of the truck.
