GAUGES, which ones are important
Old Nov 9, 2003 | 11:23 AM
EastcoastEnt's Avatar
Lookin to put 3 pillar gauges for my 02 L...
1 Boost
2 Nitrous Pressure
3 ??????????
Not sure what i should put for the third....
i would like to put something that is useful,,
was thinkin air/fuel ratio, fuel pres, pyro, trans temp, or water temp
let me know if you have any sugg...
thanks
Old Nov 9, 2003 | 12:15 PM
Ruslow's Avatar
The ones that are critical are the ones I use.That is if I see something not rite I can help prevent a problem.Boost is nice to see but what good does it tell you to help your motor?All I see out of it is bragging rites.Now oil psi is different.The so called gauge is NOT a guage.It is a form of idiot lite.It does not move up or down when the engine rpms change!Put guages in that you will use!And to help prevent damage.I run a fuel psi gauge and egt [2 channel].Then an idiot lite for the oil psi as well as an accusump system for oil.And thats it!A/F guages look nice at nite but are to inaccurate to be used for anything else.EGT tells you the a/f indirectly in that as temps go up the a/f goes lean.Get the idea?But it is up to you.buy what you want.the NO2 guage is a good one to start with.Stan
Old Nov 9, 2003 | 02:00 PM
LightninMike's Avatar
if your going to run juice deff get a fuel pressure guage
i belive that is a must have for your application
Old Nov 9, 2003 | 02:06 PM
MISTERgadget's Avatar
EGT, Fuel Pressure, and Tranny Temp
Add a boost gauge on the steering column
Old Nov 9, 2003 | 03:38 PM
LatemodelRacer2's Avatar
NITROUS, BOOST and EGT on pillar and Fuel pressure on column
Old Nov 9, 2003 | 03:52 PM
LightningCT's Avatar
for the stupid one here, what's egt (i probably know it, but the beer from last night is slowing my thought processes)
Old Nov 9, 2003 | 03:54 PM
dirtchicken's Avatar
Exhaust gas temp.
Old Nov 9, 2003 | 03:55 PM
thanks chicken
Old Nov 9, 2003 | 03:58 PM
No problem. I surf this website all day at work. I got Lightning withdrawal.
Old Nov 9, 2003 | 04:05 PM
yeah, me too....hoping someone in my family hits the lotto so i can build the motor, add no2, blower upgrade, blah, blah....aaaaaahhhhhhh sometimes i hate this truck....LMAO
Old Nov 9, 2003 | 04:08 PM
I am in Japan for about three more weeks. I have about $15,000 worth of stuff at the house for the truck including a built long block with Crower Stage II cams, nitrous and all the other goodies. I have a ton of bling too, Sir Michaels roll pan, 20" rims and too much other stuff to list. I will be adding a KB in October of next year.
Old Nov 11, 2003 | 07:05 PM
you're one lucky SOB....lol
Old Nov 11, 2003 | 07:56 PM
svtguy2002's Avatar
I went with trans temp, oil pressure, and fuel pressure on the pillar and water temp and boost on the column. I attached an Autometer gauge cup onto my steering column pod (a la Easterisland). I was going to go with an Pyrometer, but decided to go with a wideband sometime this winter instead.
Here's a pic:
Old Nov 11, 2003 | 08:12 PM
VINNIE's Avatar
Here's a pic:
Old Nov 11, 2003 | 09:13 PM
svtguy2002's Avatar
Originally posted by VINNIE
