SES and P0171 code
Hey guys I would love some help. I have a 2001 L with a chip 5lb lower pulley and full exhaust. Recently I threw #3 plug. I had the supercharger removed and a few other things in order to have #3 helicoiled. After it was repaired the SES light came on.I scanned it and got P0171 system too lean. What could be the cause of this? I have an oil breather on for quite soon time now with no problems. I changed the fuel filter the same day too. What else should I check in order to solve the problem? Any responses would be greatly appreciated.
Thanx Cypri.
Thanx Cypri.
I checked again and I actually got:
P0171 system too lean bank 1
P0174 system too lean bank 2
P0402 EGR excessive flow detected
How I think I got an even bigger problem. Any please help with suggestions.
make sure all of the vacuum lines are routed and connected properly. There is either a vacumm leak or line not connected lettign unmetered air into the engine. Something like that causing a lean condition. Don't forget the ones to the EGR tube to the transducer.
Re: SES and P0171 code
Thanx Cypri.
Thanx Cypri.
