Upper pulley removal question
Hey guys which way do you turn the pilot screw in the blower snout on the Lightning in order to remove it? Thanks, sorry for such a boring first post but I'm in the middle of a project.
Arthur
Arthur
Thanks, I'm using the Pulley Boys pulley removal tool that I have used on previous occasions to remove the stocker and re-install a DUB hub. I just wanted to make sure that as far as that particular screw is concerned that I was wrenching in the correct direction. It is on tighter than you can imagine and has turned this half hour job into a 1.5 hour job and counting. Thanks for the help ---- Arthur
