Built shortblock question
Old Nov 4, 2003 | 01:33 PM
Twinturbo Ranger's Avatar
On all the built shortblocks offered are there any compression ratios being changed or is that a option?
Thanks Mike
Old Nov 4, 2003 | 02:02 PM
tommylightning's Avatar
We use CP 17cc dished pistons. I am sure others are offering different combos. Just remember, more boost will always give you more hp than more compression.
Old Nov 4, 2003 | 03:23 PM
Exactly why I was asking
I'm was thinking of lowering the compression from stock so I could run more boost on pump gas.
Thanks Mike
Old Nov 4, 2003 | 03:30 PM
Justin@JDM's Avatar
Banned
Mike,
Stock compression- 8.4:1
JDM Short block compression- 8.5:1
JDM short block with our CNC ported heads- 8.0:1, because of the CNC work we do in the chamber area.
Hope this helps,
Justin@JDM
Old Nov 4, 2003 | 07:10 PM
Thanks Justin, that does help. Do you have to exchange your longblocks? I'm just pondering ideas on what I might do. I haven't done anything since I spoke to you on the phone the other day,but things will start happening soon once I get a couple things lined out.
Thanks Mike
