13.58 @ 100.0 Stock Time
Old Nov 1, 2003 | 05:26 PM
swiseuf's Avatar
13.58 @ 100.0 almost Stock Time
First time at the track ( Gainesville FL) I ran a 13.58 @100, and a slew of 13.6's. Track conditions were 82 degrees with a steady 10-15 mph headwind. Here are my three best times-I am stoked to say the least. Truck is almost stock with removed spare, KN drop in panel filter in stock unmodified box, and the boost bypass trick.
Run 1 / 2 / 3
R/T .297 / .240 / .288
60' 1.95 / 1.98 / 2.04
330' 5.64 / 5.69 / 8.77
MPH 80.82 / 80.38 / 80.53
1000' 11.33 / 11.40 / 11.43
1/4 13.58 / 13.66 / 13.68
MPH 100.01 / 99.82 / 100.08
By the way, the track was EMPTY! If anyone in JAX/Ocala etc wants to T&T, there will be another Saturday session on November 8.
Old Nov 1, 2003 | 07:35 PM
Rob_02Lightning's Avatar
AWESOME ET for no Mods
WAY TO GO swiseuf
CONGRATS
Just wait til you add 6lbs of pulley,
Old Nov 1, 2003 | 07:45 PM
fractaldragon's Avatar
Re: 13.58 @ 100.0 Stock Time
Originally posted by swiseuf
First time at the track ( Gainesville FL) I ran a 13.58 @100, and a slew of 13.6's. Track conditions were 82 degrees with a steady 10-15 mph headwind. Here are my three best times-I am stoked to say the least. Truck is stock with removed spare, KN drop in panel filter in stock unmodified box, and the boost bypass trick.
That's NOT stock. Try full weight, no bypass, and paper filter then you are stock Good 60fts tho!
Old Nov 1, 2003 | 08:09 PM
DR.D's Avatar
he's right
that's not considered "stock" by us. Stock is untouched factory equipped. Not to burst your bubble 'cause that's still good. Some have hit 13.3 (me for one) but that may depend on area, temp, humidity.......... Some may have even hit a .2. So at least you can still feel good about it 'cause that ain't bad at all.
Old Nov 1, 2003 | 08:20 PM
swiseuf's Avatar
to satisfy the purists, I changed my thread heading.
Old Nov 1, 2003 | 08:32 PM
DR.D's Avatar
you go boy
great attention to detail.
Still a good run, guy.
Noone means anything bad just that stock has been just that. Then you base your inreased performance on yer mods. Stock is the baseline you need to justify bucks spent.
What color?
Old Nov 1, 2003 | 09:39 PM
Old Nov 1, 2003 | 09:53 PM
Blown93's Avatar
In 82 degree heat , man your flying .. great runs..........
PEacE.......................
Old Nov 1, 2003 | 09:54 PM
chiketkd's Avatar
swiseuf
That was an awesome stock run!! I mean if we all started to nit-pick, someone with a factory stock L who lowers his rear tire pressures to 24 psi is not 'stock' (owners manual states tire pressure should be 32psi).
My only 'mod' in my L is a K&N panel filter. Earlier this year when I blew a spark plug, Ford only honored the warranty as my truck was 'stock'.
13.58 with no spare, boost bypass and K&N is awesome. The trap speed shows that your truck was making stock HP.
Old Nov 2, 2003 | 09:50 AM
mikes2lights's Avatar
THATS GOOD
BEST ET STK ON F1S AT ETOWN,NJ
51 DEG 49% HUM
13.609 100MPH
Old Nov 3, 2003 | 04:13 AM
AmoJohnny's Avatar
these are badass times, eyy, who knows of a good track near los angeles? I wanna try out my stocker times.
Old Nov 3, 2003 | 11:19 AM
ShaneMcKenna203's Avatar
Great #'s for almost stock... I'd be real happy running 13.5 with just a drop in filter. Congrats you've got a beast!
Shane
