My new IC Cooler
Old Oct 29, 2003 | 09:38 PM
Red BOLT99's Avatar
My new IC Cooler
Just hought I'd show off my new cooler
20gallon fuel cell with 25ft of alluminum coil in it.
Stock pump is running like a charm. 180 spent aint bad!
And I know my truck bed is trashed but its because of all the ash falling from the fires locally.
Old Oct 29, 2003 | 09:40 PM
MaxPower's Avatar
Thumbs up
Awesome!
...we want details on the install!
Old Oct 29, 2003 | 09:41 PM
Red BOLT99's Avatar
pic under the hood
Old Oct 29, 2003 | 09:53 PM
l-menace's Avatar
this is my EXACT winter project for the L.
any details you want to give are appreciated!
also, Are you only using the stock intercooler pump and nothing else?
Details man Details
Old Oct 29, 2003 | 10:04 PM
Red BOLT99's Avatar
So details
Summit allum, 25 gallon cell
25 or so feet of allum, coil
30 ft of heater hose ran on the pasenger side of the frame to under the bed.
Cut one whole side of the cell off and plumed my coil inside , welded to bungs to the back of the cell and the coil to the bungs.
Ten hoked up some earls ends and some caps on top an that was it.
yes I am using stock pump and it is flowing fine.
I'll have better pics up soon!
Old Oct 29, 2003 | 10:59 PM
hslightnin's Avatar
what u mean alum coil?
Old Oct 29, 2003 | 11:32 PM
Red BOLT99's Avatar
Old Oct 29, 2003 | 11:38 PM
Red BOLT99's Avatar
Old Oct 29, 2003 | 11:48 PM
Red BOLT99's Avatar
Some more pics with my custom flames.
Old Oct 30, 2003 | 12:33 AM
l-menace's Avatar
I take it the "coolant" is a sealed system and when you go to the track you fill the BOX with Ice.
the coolant going through the box and through the tubing is Chilled by the ice.
Is there condensation on the hose going back to the Intercooler?
What size hose did you use? Fittings?
Does the Bos have a drain to drain the melted Ice?
Is the single stock pump string enough to pump it through all that tubing or would another inline pump help out?
What about Heat Exchanger, are you using hte stock one?
what did you use to protect the lines going under the truck?
could debris puncture it?
Was it difficult to bleed the system?
how much coolant does it hold?
This is one of my winter projects, that's why there is 100 questions
Old Oct 30, 2003 | 08:32 AM
superfords's Avatar
for anybody thinking of making their own "PowerCooler" check out Reichard Racing, they make a trick aluminum filler opening/cap assembly. It is larger than normal. It even says "for water only". That was my one beef with the JLP powercooler, the opening was so small that it was a real PITA to refill with ICE. the RR cap is substantially larger and should make filling much easier. I just checked their website and couldn't find it, but I saw them on display at MIR a couple of weeks ago.
later,
chris
Old Oct 30, 2003 | 09:53 AM
Red BOLT99's Avatar
I-menace
1. The box is a sealed system
2. I am not getting condensation on the lines
3. The drain plug will be going on 1 of the plugs by the tailgate.
4. the pump seams to be working like normal if you look at my resivor its a moroso can so to check I put my fingers in befor and after and the presure feels pretty much the same.
5. I do have an aftermaket heat exchanger. I think it helps as a combo.
6. The hose's running under the hood next to motor I put thermal wrap on them. And after that that they are bare tuked up close to the frame and body. I will be puting some type of sheild eventualy.
7. Didn't pay attention on how much more coolant I used. But I did add a new can of Water-Wetter.
On the bleeding I think its self bleeding there really is no where I could get air pockets?
As for the the filler cap on the cooler I have a funnel cut to fit the opening just right and the top an 10inch opening so I shouldn't have to much trouble for know. And will upgrade if I find a better filler cap, I'll look into that cap thanks Superfords
