Electric Water Pump and Electric Fan?
Old Oct 27, 2003 | 11:56 PM
l-menace's Avatar
Anyone Using PSP Electric Water Pump?
It says you must use it with an E-Fan.
If so, what are your thoughts on the E-Water Pump?
Old Oct 28, 2003 | 12:09 AM
Don's Bolt's Avatar
As long as it is the new version it is fine.
You can also go for a electric fan and cobra water pump. The electric fan only frees up a few HP. Unless you plan to use it at the track to circulate the coolant to cool down, the cobra pump is just as good.
The Cobra Pump prob is more reliable too.
Old Oct 28, 2003 | 12:28 AM
Probleminfected's Avatar
add one of these to the cobra pump and you'll get even more happy
http://www.rpmoutlet.com/lightfan.htm scroll up
Old Oct 28, 2003 | 01:14 AM
promodlightning's Avatar
Will there be any overheating problems with that underdrive pulley?
Old Oct 28, 2003 | 01:15 AM
no actually, cooling will be better, gives the coolant/h20 more time to soke up the heat
