JDM Heat Exchanger
Old Oct 27, 2003 | 10:42 AM
metroplex's Avatar
JDM Heat Exchanger
I'll be installing an Eaton M90S-Ported blower (AED Kit) on a Ford Crown Vic, the stock exchanger is a Perma-Cool 24k GVW tube/fin cooler!!!
I was told this is TOO small and that upgrading would be a great idea.
Should I go with the stock Lightning exchanger or the JDM exchanger or something else???
It's a 6 psi kit and the reservoir/degas bottle is smaller than a coke can.
Any advice would be appreciated.
Old Oct 27, 2003 | 10:49 AM
whip's Avatar
If you can get a good price on a JDM unit it would be sick..even overkill. I think for that blower a stock lightning unit would be plenty. I'm sure you can get a good deal on someones old stocker kickin' around! Good luck! I'm jelous...I always wanted a hotrod vic!
Old Oct 27, 2003 | 10:50 AM
Lightning Boy's Avatar
Find a stock Lightning heat exchanger. It'll do the job well for you, and be cheaper than the beefed up JDM/Fluidyne unit.
Old Oct 27, 2003 | 11:15 AM
metroplex's Avatar
Ok I just wanted to know what the Lightning pros thought...
The Vic I have uses a 2000 Ford 4.6L SOHC V8 (Romeo) w/ NPI heads.
It weighs 4200 lb in race ready configuration and is mated to a 4R70W. I have stock 3.55s in the back with a Torsen differential.
You think with a 6 psi Eaton M90S-Ported blower I would be more than Ok with a stock Lightning exchanger?
If you've ever seen the stock reservoir - you'd know its shrimpy.
Here's the site:
http://www.allenengine.com/cvinstall3.html
It's a bit of a read so just look at the pics. That reservoir is the metal can near the master cylinder reservoir w/ that radiator cap.
The stock exchanger is a PRM-1316 (24k GVW tube/fin Perma-Cool ATF cooler) - POS and Puny.
Could I use TWO stock Lightning Exchangers in series w/o worrying about too much restriction? The AED mechanical coolant pump isn't very large, I wanted to install a drag racing radiator but I think that's TOO much work for a little pump.
Old Oct 27, 2003 | 01:10 PM
action 911's Avatar
Hey,
I have one. I will part with it for $100.00.
Herb
Old Oct 27, 2003 | 01:11 PM
action 911's Avatar
Also I think one is all you need.
Herb
Old Oct 27, 2003 | 01:47 PM
BigFan's Avatar
MetroPlex, While the bigger heat exchanger will help, you wont see a big difference in power if your intercooler isnt effiecent. I dont know if you have been to the TBird sites, but I would email a guy by the name of Mike Siska. He also goes by ECCDOC on the Corral, Mike has done alot of work with his AED Tbird and last I heard was will into the 11's on a daily driver. It has been a while since I last spoke to Mike, Things might have changed.
Old Oct 27, 2003 | 01:50 PM
metroplex's Avatar
The intercooler is whatever that comes with the M90S-ported Eaton blower, I'm not sure how I could make it more efficient?
I'll talk to him, I know A-train who is friends with Mike.
Old Oct 27, 2003 | 02:22 PM
LatemodelRacer2's Avatar
JDM had a couple stock ones for sale a few weeks ago not shure if they have them now.
